WB Lambda
Old Dec 9, 2002 | 08:46 AM
Racing's Avatar
WB Lambda
If you clicked on this thread you´re probably aware of what a wideband lambda sensor is,and that buying stand alone systems(converter and sensors) are fairly expensive.
Not only that,but the NTK UEGO has skyrocketed in price range also.
Here´s the deal.
We´re a team of enthusiasts that are currently well under way of putting together a digital converter based on the currently available Bosch sensor instead.
The digital converter will be able to sample not only the WB data,but we´re at the moment trying to figure out the neccesary other input as well.
Ie; TPS voltage,MAP voltage aso.
The cheapest resource for OEM install Bosch´s at the moment seems to be Volvo.
We´re thinking along the lines of marketing this digital box including software needed to run via laptop,and the price range will hoover around the 350$ mark.
Sensor will run another 150 approx.
Would you in this case have interest in such a tool for said money?
Old Dec 10, 2002 | 12:11 AM
KTamez's Avatar
Thumbs up
Thats a pretty good value, considering the dough that MoTeC and the couple other companies that I've seen ask for the Stand alone WB02 setups.
Just an idea, but you may wanna toss this into the Forced Air Section guys. I'm sure they'd eat this up!
Kurtis "Wideband Equipped" Tamez
Old Dec 10, 2002 | 06:24 AM
Racing's Avatar
Thanx Kurtis.
For the old timers of this board...you know exactly where i´m coming from with this.
Any and all input is greatly appreciated.
Old Dec 10, 2002 | 02:20 PM
Slow95T/A's Avatar
kinda like this ?
http://www.lambdaboy.com/
95redLT1
32
Jun 1, 2010 07:40 AM
Z284ever
24
Nov 26, 2006 10:27 AM
421 vette
Jan 5, 2006 09:44 AM
Z284ever
19
Oct 22, 2005 10:25 AM
