TB difference!!
Old Nov 30, 2007 | 01:59 PM
LastBreedLS1's Avatar
TB difference!!
What's the difference between cable driven or wire driven TB on a LS1? I heard about it, but wasent sure. thanks for anyones help!
Old Nov 30, 2007 | 04:03 PM
Marc 85Z28's Avatar
Self explanatory...
The cable TB has a traditional throttle cable. The drive-by-wire eliminates the cable, and uses the PCM to control a motor on the side of the throttle body.
Old Nov 30, 2007 | 05:06 PM
what do you need to make it a wire driven? this is all new to me!
Old Nov 30, 2007 | 08:58 PM
Kraest's Avatar
Retired
The Vette and GTO use a computer controlled TB.
The F-body uses a standard throttle cable to open/close the TB.
Not really sure what you're asking...
Old Dec 1, 2007 | 08:45 AM
AL SS590 M6's Avatar
Moderator
You can not use a drive-by-wire TB on an f-body.
Old Dec 1, 2007 | 01:18 PM
Bayer-Z28's Avatar
^ yeap.. No can use on F-Body.,.. Unless you replace the entire PCM/ECM w/ an LS2/7 also..
No real difference. Other than the 90mm TB.. It also eliminates the IAC and TBS sensor and separate TCS/ASR system.. The single 'Drive By Wire' system combined w/ the ECM monitors all the TB activity and controls for TCS and controls IAC.. It's basically an all in one system..
On a side note.... I've recently driven an 06 GTO.. I liked it! VERY smooth! But my 00 Z28 seems to have more snap, feels more like a beast than the GTO. The GTO just felt a little heavy. Almost felt like the same power minus a couple ponies on the 06 (comparing to my Z, the feeling)..
Old Dec 1, 2007 | 08:30 PM
so i shouldent even bother with it. if that's the case then you guy's have said enough. thanks for the info. I'll stick to my cable!!
WobblySausage
Oct 7, 2015 02:44 PM
NewsBot
Sep 30, 2015 04:20 PM
SergheiS
Sep 29, 2015 08:56 PM
Bxlt1
Sep 29, 2015 03:18 PM
