Does anyone else have DART Pro 1 Aluminum Platinum heads?
Old Nov 27, 2007 | 10:42 AM
Kurt Crosbie's Avatar
I just got a set and they are advertised at 64cc, but I figured I would just ask around so I wouldn't have to mic them.
Old Nov 27, 2007 | 01:25 PM
SStrokerAce's Avatar
Chamber volume also depends on the valves and where the valve job is placed in the heads
Old Nov 27, 2007 | 04:59 PM
mdacton's Avatar
how are you going to mic the head? I have never done that before, is this something new?
Old Nov 27, 2007 | 06:06 PM
1989TransAm's Avatar
I have a set of the Dart Pro One 200cc heads for my SBC. They are advertised as 64cc. In fact mine were over 69cc. By flat milling we were able to bring them down to 64.2cc. So you might want to have them checked. They are fine heads though.
Old Nov 27, 2007 | 08:56 PM
How exactly do I check them? I thought it was process using a "mic". Maybe I misunderstood the instructor. I assumed it was a process where you measure the volume of the combustion chamber with a liquid while the valves are shut.
Old Nov 27, 2007 | 09:02 PM
jerminator96's Avatar
You fill the chambers with a liquid while they are assembled, make sure it's level, then remove it with a syringe and measure.
Old Nov 27, 2007 | 10:00 PM
Yeah no micrometers involved, just a burret
Old Nov 27, 2007 | 10:02 PM
rskrause's Avatar
Moderator
Or even just a needleless syringe (get one at a pharamcy). Seal the valves with a little grease (unless you do one hell of a valve job).
Rich
Old Nov 27, 2007 | 10:03 PM
Yeah runout would have to be under .001" and have the **** lapped out of them
Old Nov 28, 2007 | 03:19 AM
AdioSS's Avatar
West South Central Moderator
What instructor? What school?
Old Nov 28, 2007 | 11:00 AM
I've got a friend that is attempting to teach me a lot of this stuff over the phone. He's pretty good at what he does, but he has no formal education.
But I am an engineering student.
Old Nov 28, 2007 | 11:04 AM
rskrause's Avatar
Moderator
A CC is a very irregualt shape. Would be practically impossible to calculate the volume by taking measurements.
http://www.hydrostream.org/ArticleArchives/CCHeads.htm
Rich
Old Dec 2, 2007 | 07:13 PM
marshall93z's Avatar
I must have "lapped the **** out of mine then"! Measured CC and the ports and never leaked any fluid.
Old Dec 2, 2007 | 08:06 PM
A couple of guys here locally have the SBC versions. Couple of problems. The stock valve covers and some others will not fit. The accessory holes on the ends of the heads are not deep enough. Either shorter bolts or washer the ones you have.
Old Dec 2, 2007 | 08:38 PM
Who cares Kurt is selling his now
