Vacuum Canister behind Rear drivers tire
Old Nov 25, 2007 | 09:07 AM
walt355's Avatar
Do you need it, I was told not but I went to take it off and its got a line running to the gas tank, can I plug this?
Old Nov 25, 2007 | 09:49 AM
Its not a vacuum canister, its the charcoal canister for the fuel tank vent system. If you remove the EVAP components (line from the canister to the engine compartment, EVAP purge solenoid, line to the throttle body), there is limited use for the canister. It reclaims the vented fuel vapor so it can be burned in the engine using the purge system.
For my "track only" car, I removed the canister, and put a filter sock over the line from the fuel tank. That line still needs to be there to vent the pressure/vacuum in the fuel tank. You may notice an increase in fuel smell at the rear of the car.
Old Nov 25, 2007 | 01:44 PM
walt355's Avatar
Thanks Fred, Thats the way I will go then. I apreciate it
RUENUF
May 25, 2016 08:10 PM
dale3in98
Feb 14, 2015 12:18 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Snoman73
Nov 17, 2014 07:22 PM
