Autocross and Road Racing Technique There is more to life than a straight line
Short belt to bypass A/C
Old Dec 7, 2002 | 06:40 PM
pastrdcp's Avatar
Wink Short belt to bypass A/C
Has anyone installed a belt to bypass the air conditioner pully?
Old Dec 9, 2002 | 04:07 PM
veryslowfbody's Avatar
Go to Autozone and get a A/c delete pully and a A/C delete belt.
Old Dec 9, 2002 | 05:15 PM
94bird's Avatar
I don't think you can bypass the AC compressor without removing it. If you do choose to remove it, you can use the stock length belt because you have to replace the compressor with an AC delete pulley.
I'm planning on doing this over the winter myself. The part number for the AC delete pulley should be 10115875.
Old Dec 9, 2002 | 08:24 PM
Dr.Mudge's Avatar
I used the pully and a stock replacement sized belt, the old belt was stretched and would not fit, but I dont see how you could bypass it and maintain proper tention especially since the tensioner would now be worthless.
Old Dec 10, 2002 | 10:55 AM
kgkern01's Avatar
Is there a belt that can be used just to bypass the A/C on an LT1? Still want the A/C for summer but want to be able to bypass by changing belts if necessary.
Old Dec 10, 2002 | 03:29 PM
94bird's Avatar
Don't mean to be short, but see above.
Old Dec 10, 2002 | 05:30 PM
Dr.Mudge's Avatar
You can simply unplug the AC if you wanted, but I dont know that you'd get any benefit at all, half the benefit IMO is just simply getting rid of weight, so I wouldn't bother if you want to retain your AC.
Again, I dont see how it would be possible, in the old days you created your own tension usually by moving the alternator around since it was on a sliding bracket, however on this car you have a spring loaded tensioner, and you'd end up taking it out of the loop if you used a shorter belt without the AC.
Old Dec 21, 2004 | 03:26 PM
Eff's Avatar
Eff
Re: Short belt to bypass A/C
nope, thats the water pump pully
Old Dec 22, 2004 | 03:49 PM
Timmy3800's Avatar
if this is for your 97 V6, then you dont need a new pulley. my belt id 62 inches and it goes around my alt to the power steering, around the crank and then around the water pump. you can drop the alternator to help get it on, and the tensioner pulley will keep tension on the belt. you can leave your a/c on and you dont have to unplug it. if you aren't going to use your a/c anymore i would recommend you pulling it out. it only takes about a half hour and it weighs about 60-70 lbs. if you have any questions i will post a link to a pic of my route.
Old Dec 22, 2004 | 03:53 PM
Timmy3800's Avatar
if this is for your 97 V6, then you dont need a new pulley. my belt is 62 inches and it goes around my alt to the power steering, around the crank and then around the water pump. you can drop the alternator to help get it on, and the tensioner pulley will keep tension on the belt. you can leave your a/c mounted and you dont have to unplug it. if you aren't going to use your a/c anymore i would recommend you pulling it out. it only takes about a half hour and it weighs about 60-70 lbs. if you have any questions i will post a link to a pic of my route.
Old Jan 5, 2005 | 10:08 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
just turn the AC off. it uses very little power when it is not on since it is clutched.
Old Jan 5, 2005 | 10:42 PM
94bird's Avatar
Wow, 2 years later I get a correction. Well, I got an A/C delete pulley from Lambert as many others have before me and it worked great. Don't have the part number in front of me if that number was incorrect.
Old Jan 5, 2005 | 11:41 PM
Eff's Avatar
Eff
yeah I was wrong, shoebox corrected me on another thread
appearently waterpump was the catagory
Old Jan 6, 2005 | 07:20 PM
94bird's Avatar
I didn't want to say anything, but there is no water pump pulley on a LT1.
Old Jan 8, 2005 | 01:16 PM
Z28barnett's Avatar
FYI, Ford did build airplanes.
The Ford Tri-Motor was one of the famous ones.
