Does anyone elses heat suck??
Old Dec 7, 2002 | 05:57 PM
LT1Thunder's Avatar
Angry Does anyone elses heat suck??
I don't know why but my car is so damn cold!! It takes forever to blow out warm air, and when it does it's not even that warm at all. The temperature stays at around 180* so shouldn't that be warm enough to actually have good heat? When the temp goes up higher from being in traffic it gets a little warmer but as soon as I start moving the car goes right back down to 180* and the air is cooler again! It really makes for an uncomfortable ride late at night when it's like 20*outside. Does anyone else have this problem?
-Rick
Old Dec 7, 2002 | 06:20 PM
Could be that the temperature **** is not moving the mix door that routes the hot air or the door itself is stuck.
Old Dec 7, 2002 | 06:26 PM
1BadBird's Avatar
Do you have a 160 deg. Thermostat? I do and I have the same problem as you and believe it to be the thermostat. I am going to take my Hypertech programming out and try that for a day or two(just as a lazy fix) if that don't help am gonna put a hotter thermostat in. Guess that'll be another for the winter thing to do. I'll try to let ya know what happens.
Old Dec 7, 2002 | 06:27 PM
LT1Thunder's Avatar
How do I see if something is stuck? I have know idea where to look.
Old Dec 7, 2002 | 06:49 PM
Lunarson's Avatar
Mine has been that way for as long as I've owned it, hard to warm in the winter-hard to cool in the summer.
Old Dec 7, 2002 | 06:56 PM
camaro4lifez28's Avatar
take your heater hoses off of the hoses coming off the fire wall, and use a garden hose and spray out the heater core. I just did mine and it helps alot.
Old Dec 7, 2002 | 07:39 PM
You will have to access the back of the control **** to see if the cable is being moved properly, if it is then you can check it at the other end at the mix door.
Could be a clogged heater core like camaro4lifez28 said, too. That is more likely the problem.
Old Dec 7, 2002 | 07:45 PM
LT1Thunder's Avatar
Thanks a lot guys for your input. I will have to check it out a little more when I can bare the temperatures outside.
-Rick
Old Dec 7, 2002 | 08:54 PM
WheelmanZ28's Avatar
I hear u Rick, I'm having the same damn problem. I'm thinking it has to be something to do with the thermostat. But i could be wrong cuz my friends 94 Z28 runs cooler then mine and his heat DOES work fine.
Old Dec 7, 2002 | 08:56 PM
when i forced water through my heater core, nothing but brown crap came out. After that i had heat. Mine was completely clogged
Old Dec 7, 2002 | 08:58 PM
Grease's Avatar
I have a 160 degree thermostat and my car ran so cold in the winter I couldn't use the heater otherwise the needle would never lift. I fixed it by unplugging my fans. Infact I drove it last winter, for about 3 months with no cooling fans. I didn't even overheat when It was in traffic, so long as the heat has been switched on.
Old Dec 7, 2002 | 09:02 PM
JSK333's Avatar
I think most of your experiences are not the norm.
I have 160* t-stat, temp for fans lowered to 82/85*C, and I get LOTS of heat in the winter, even in the recent sub 20*F snow weather. I use about a 80/20 mix of water/anti-freeze, with DEI Radiator Relief (like Water Wetter).
I mean... it'll get hot enough that I have to turn it off and just let the air be pulled through from the car moving. And the temp gauge still goes up fine.
So, I suggest you get your cooling system flushed and fill with a good mix of mostly water. Works great for me!
Old Dec 7, 2002 | 09:14 PM
RENE95Z's Avatar
My heat sucked too until I flushed it like camaro4lifez28 did. Heater never worked better since. Brown stuff came out just like his. Try it, worse thing that could happen is your heater core gets flushed.
Old Dec 8, 2002 | 11:44 PM
LT1Thunder's Avatar
I guess i'll have to try to flush it out and just see what happens. I just hope it works cause it's getting pretty damn cold outside.
Old Dec 8, 2002 | 11:57 PM
drop top steve's Avatar
That sounds like a mix door stuck in the hvac box. Or a vacuum line/solinoid.
