Huge Vibration
Old Nov 14, 2007 | 03:37 AM
clcam97's Avatar
Huge Vibration
i just installed a new fidanza aluminum flywheel w/ a stage 3 maddog clutch and pressure plate,my 97 Z has LTs,MT drag radials,1.5 drop,CAI and couple of other minor bolt ons,the whole damn car vibrates a lot when i release the clutch slowly only from a dead stop it started it doing this just before my clutch went out,anyone has any idea what it could be?
Old Nov 14, 2007 | 04:43 AM
awdfun's Avatar
Flywheel balance?
Old Nov 14, 2007 | 08:30 AM
Z-RATED94's Avatar
You might have better luck with your question in the Drivetrain forum.
Old Nov 14, 2007 | 08:43 AM
Just to clarify.... the vibration started with your old clutch/flywheel????
Did the new clutch/flywheel change the vibration in any way?
Old Nov 14, 2007 | 02:08 PM
clcam97's Avatar
the vibration started with the old clutch and flywheel,just my clutch went out so i decided since i was going to replace the clutch i might as well replace the flywheel too,we pulled off the old clutch and flywheel out, and just put the new ones on,i didnt balanced the flywheel ro did anything like that cause supposebly it didnt needed to be balanced.
Old Nov 14, 2007 | 02:09 PM
clcam97's Avatar
and no, the vibration its the same
Old Nov 14, 2007 | 03:49 PM
FivePoint7z28's Avatar
Only when you take off or while youre driving down the road also?
Old Nov 15, 2007 | 12:56 AM
clcam97's Avatar
only on the take off,if i rev the engine high and then drop the clutch it doesnt vibrate,only when i release the clutch slowly
Old Nov 15, 2007 | 10:52 AM
rLyTa1n's Avatar
If you bought a Fidanza aluminum flywheel than it definetly needs to be balanced. When I got my aluminum flywheel from fidanza there were like 4 stickers and like 2 sheets of paper that said the flywheel needed to be balanced to the stock flywheel before it goes in the car. That could explain your vibration. Call Fidanza and see what they say, they said mine needed balancing, I got mine done by a shop but if you send Fidanza both your stock and new flywheel, they will balance it for free. I got mine balanced for 50 bucks at a shop here in DB. Hope this info helps alittle. Peace.
Old Nov 15, 2007 | 03:02 PM
clcam97's Avatar
thanks for the info rLyTa1n i'll check on that
autoxr166
Sep 25, 2015 04:21 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
mark0006
Aug 22, 2015 07:23 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
