Cutting siphon tube from bottle valve?
Old Nov 9, 2007 | 02:28 PM
Compstall's Avatar
I just got an NX dry kit for my bike. Bike or car, I'm sure it's all relative...
The tech support guy at Nitrous Express told me to cut the tube off the valve flush. "Dry kit doesn't matter, and you're spraying through the air filter anyway..."
Can someone explain this since I don't understand why you'd want to take that siphon tube out....
Old Nov 9, 2007 | 09:24 PM
Z-RATED94's Avatar
I have no idea. But thats usually me. Does it have anything to do with how the bottle will be mounted. As in upside-down?
Old Nov 9, 2007 | 09:28 PM
Compstall's Avatar
I asked him that, and told him my bottle will be mounted parallel w/ the ground, but he said it didn't matter.
Old Nov 12, 2007 | 10:55 AM
Ray@NitroDaves's Avatar
if you are mounting the bottle parallel ...face the valve to the rear w/no siphon tube...under accelleration the liquid will be kept at the valve by the G-forces.
Old Nov 12, 2007 | 09:35 PM
HardcoreRM125's Avatar
^ He definatly knows his N20 lol. I was sitting here like WTF? Trying to think why you wouldnt need/use it.
Old Nov 16, 2007 | 03:08 AM
97SS0594's Avatar
id still keep a syphon tube in there unless your planning on mounting the bottle upside down. cutting the tube down is realy easy fyi, just need a tubing cutter and take your time. also if you want to remove it it should just screw onto the valve, or atlest mine did.
Old Nov 16, 2007 | 01:55 PM
Compstall's Avatar
The tube is epoxied into the bottle valve.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alphaauto
Jan 23, 2015 07:42 AM
