New England Area For members in Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, and Vermont.
Vids of Turbo LT1
Old Nov 5, 2007 | 01:30 PM
RealQuick's Avatar
Vids of Turbo LT1
Just thought you guys would like to see this. It a turbo LT1 (I built the hotparts )... pretty much a stock motor, but he has forged rods/pistons and 1.6RR's. Everything else motorwise is stock.
He saw 6psi in 1st and 2nd gear, and it crept up to 8psi in third gear. He is only running 15 degrees timing because his knock sensor isnt working. He should be running 24-26 degrees to optimize his setup at the curent low boost setup. He could have easily run high 10's just by changing the timing. Not bad for all STOCK heads/cam/intake/TB.
Pretty much no boost on the launch, but he knows how to set up a car.
http://media.putfile.com/turbo-formula-track1
http://media.putfile.com/turbo-formula-track2
Here is the actual thread:
http://web.camaross.com/forums/showthread.php?t=552477
Enjoy!
Old Nov 5, 2007 | 07:58 PM
CamaroRacing12's Avatar
i saw that over at ls1tech... very impressive realquick... ur work is proven... makes me want one to go for one of ur turbo setups more and more lol... but im still gonna go for the bolt on record first
Old Nov 5, 2007 | 08:25 PM
RealQuick's Avatar
Awesome goal bro. Its gonna take faster than an 11.9 to beat it. Tough to do, but worth the glory. Only problem is that once you get it, then you line up against a stockish turbo'd LT1, you'll be in trouble
Old Nov 6, 2007 | 11:07 PM
once i achieve the LT1 bolt on record i dn wat direction im going to go in... i was thinking about spraying the car with just the bolt on's.... and turn up the spray until the motor goes... then maybe a LSx swap? who knows
Old Nov 10, 2007 | 03:34 PM
RS96Silver's Avatar
that thing is pretty sweet
Old Nov 12, 2007 | 10:50 AM
RealQuick's Avatar
Thanks. Yeah his car moves out pretty good. I cant wait to see what happens when he ups the boost to 15psi... then heads/cam next year.
Old Nov 13, 2007 | 10:27 AM
RealQuick's Avatar
Update, Justin posted some cool info:
Originally Posted by 1982z28with18s
I did turn it up to 11lbs today and 16 degrees timing..... Still 91 pump gas also! Have some more tuning to do and bugs to work out, but I will say WOW it pulls a lot better. I found out my old WG spring(4lb spring) wasn't strong enough and thats why I was having problems with it opening early and not holding boost. The new 9lb spring is working great and maxed out my maf and injectors. Hopefully I can hit the track on Sunday with it on the 11lbs.
I found out also before my track runs were only on 5lbs in 1st and 2nd and 7lbs in 3rd, and now it will hold 11lbs in 1st, 2nd, and 3rd.
Also found out it weighs 3500lbs today, so it's not a light car.
What this means is that his 11.2 @ 121mph on a stockish motor was at 5psi in 1st and 2nd gear, and 7psi in third. Not bad!
Old Nov 13, 2007 | 10:51 AM
fastest stock LT1 turbo in the world?
Old Nov 13, 2007 | 11:43 AM
RealQuick's Avatar
UNfortunately he wouldnt be considered stock (forged rods/pistons and 1.6RR's). Other than that his motor is stock. I fully expect him to run mid 10.3-10.5's this weekend on 11psi and I bet he could squeeze a 9.9 @ 15psi if he pushes it. We shall see.. he may be the first in the 9's with stock heads/stock cam/stock intake/stock TB.
Old Nov 13, 2007 | 04:26 PM
wow man badass... if it wasnt for the forged rods/pistons u could call it the fastest stock internal LT1 turbo
Old Nov 13, 2007 | 10:24 PM
RealQuick's Avatar
Just goes to show you what someone can do with low boost and a well setup car. Whats funny is Justin's tune is more conservative then if he had a stock LT1 engine.
Old Nov 13, 2007 | 10:40 PM
do u have a shop realquick?
Old Nov 13, 2007 | 10:53 PM
RealQuick's Avatar
Just my home garage
Old Nov 14, 2007 | 05:24 PM
Just my home garage
is it nice? a lift?
Old Nov 14, 2007 | 07:32 PM
RealQuick's Avatar
is it nice? a lift?
Just a 2 car garage. One side has my camaro, the other side is where I work. No lift. You are more than welcome to come by and shoot the $hit.
Jon
