Need quick help on Hub Assembly
Old Oct 30, 2007 | 09:03 PM
94 Camaro Z28's Avatar
Hello all. My drivers wheel hub has been screaming lately so i went out and bought a new Hub assembly. The problem is, i cant get the stock assembly off. I've hit it with a hammer, used a chisel, put another jack under the hub and dropped the car on it. Nothing is breaking it off!!
How can I get it to separate from the knuckle? I have to wrap this up in an hour, neighbors are getting pissed at the racket .
Thanks,
Matt.
Old Oct 30, 2007 | 09:08 PM
rngilliland's Avatar
The hubs are probably rusted to the knuckle. I had trouble getting mine out too. I soaked them with WD40 and let it sit over night.
Old Oct 30, 2007 | 09:13 PM
RE AND CHERYL's Avatar
Your gonna need one of these
Re'
Old Oct 30, 2007 | 09:18 PM
mdacton's Avatar
^^ likethat...but try to fond a bigger one
get a slide hammer, soak it with some PB blaster
Old Oct 30, 2007 | 09:25 PM
I have the "Y" piece but not the slide hammer. I have some Chestertons but cant find it . I just sprayed a bit of WD-40 on it and am letting it soak.
Old Oct 31, 2007 | 08:18 PM
Well, here's an update for future reference incase anyone needs the same info i needed.
After spraying WD-40 on the assembly 3 different times, and letting it sit overnight, i was able to get it off tonight. All i needed was a little sledge hammer and hammer on the hub outwards. Slowly but surely, it came out.
(Just remember to unplug the ABS sensor )
Thanks for the help guys
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Z Power
Sep 19, 2015 11:19 PM
NewsBot
Sep 14, 2015 09:20 AM
