Plug Gap And Plug Type For Turbo!!!!
Old Oct 29, 2007 | 11:37 AM
jammer94's Avatar
is there any difference in plugs i have been using tr55 ngk's for a while now and i change them on a regualr basis and they are gapped at .55 when i was running n/a
can i stay with the TR55's but just a different gap do turbo cars require a different plug gap?
any info will be very helpful
Old Oct 29, 2007 | 02:12 PM
roguedriver's Avatar
Definitly want to tighten up the gap if your gonna boost it. Think the majority runs around the .035 or less range. If your a fan of the TR plugs, you'd probably want to go to a TR6 plug. Don't want to run something too warm and you may get spark blow out with the larger gap.
Ken R.
Old Oct 29, 2007 | 02:56 PM
jammer94's Avatar
i new about the spark blowing out with the larger gap especially set at .050 or .055 i figured .035 or .030 would be the place to be, but i didnt know about needing a colder step up plug...
what do you run interms of plug brand and material...?ken
Old Oct 29, 2007 | 06:53 PM
F.I.94z's Avatar
I run the tr6 @ .030 and it is running great.
Old Oct 29, 2007 | 08:04 PM
I'm running the Autolite racing plugs. I was running an AR472 (i believe thats 4 ranges colder then stock), but they were too cold and were fouling during daily driving. I just put in AR474's (back 2 steps warmer) and they seem to be running well. I'm running the gap at .030. Wanted to leave a little room to widen cause the gaps seem to open up fast on these racing plugs. There a non-projected tip plug with a cut back ground strap. I wanted to try out the Champion verson of the same plug, but they weren't in stock, so i went with the Autolites for now. When i originally ran a 1 step colder AC plug with a .035 gap and a projected tip, i was getting spark blow out. That didn't go away until i went with a non-projected tip plug with the same gap. Food for though.
Ken R.
Old Oct 30, 2007 | 07:59 PM
F.I.94z's Avatar
Ken It sounds like you like to change plugs
Old Nov 1, 2007 | 06:39 PM
Not really, but with a set of Kooks headers, i can change a set in about 20 minutes.
Ken R.
Old Nov 1, 2007 | 06:54 PM
LT1-TA's Avatar
Tr6 here at about .032
Old Nov 2, 2007 | 08:36 AM
jammer94's Avatar
woot woot for the NGK's i noticed on all other GM boards alot of people like using the autolite 103's which i am not a fan of those plugs on GM products.
DirtyDaveW
Dec 1, 2016 05:37 PM
Fastbird93
Apr 9, 2016 07:01 PM
blkWidow
May 3, 2015 08:42 AM
jayblev95
Jan 6, 2015 11:52 AM
SC97TA
Sep 15, 2002 01:10 AM
