Swaping out a rear end with 2.73s to one with 3.42s
Old Oct 27, 2007 | 02:45 PM
Projectcam94's Avatar
Question Swaping out a rear end with 2.73s to one with 3.42s
Im going to buy a rear end of a 96 ws6 that has 3.42 gears in it. Mine has 2.73s i know that because i checked the code in the glove compartment.
My question is will it be direct fit? Its from a 96 ws6 and my car is a 95z
Its a full rear end including the discs
Old Oct 27, 2007 | 03:24 PM
2001NBMZ28's Avatar
I'd think so but wait for others to chime in to be sure. Something else to consider is whether both cars have traction control/no traction control. I replaced mine with a M6 non-tcs rear from another LS1 car to get rid of my 2.73's - neither had traction control and was plug and play except for the speedo recal.
Old Oct 27, 2007 | 05:10 PM
Wow ... I hope it fits cuz i bought it already and have it at my house... Ill be comparing it from the one on my car.. The outside should be the same right?
I got it for 180 i was told this was a good price for it
Old Oct 27, 2007 | 05:37 PM
hotrod18_69's Avatar
Yes it will fit and work.. Do you know if yours is a 4 channel or 3 channel ABS.. Look and the new rear end.. Look on the pumpkin and see if there is a plug in on the top.. If not look on each of the caliper brackets for a plug..
If the plug is on the pumpkin its 3 channel.
If there on the caliper brackets its 4 channel.
THen compare to you rear end in the car now.. If there not the same the rear will still work. .You just wont have ABS anymore..
Old Oct 27, 2007 | 06:22 PM
Plug what kind.. I took pics maybe this will help you tell me what it is..
This is of the differential on the car right now .
This is of the one I bought
It looks like they both have some type of connection on top..
Does that mean its a 3 channel?
Old Oct 27, 2007 | 06:24 PM
Yup they both look like 3 channel to me.. You should be just fine.
Old Oct 27, 2007 | 07:25 PM
Nice Thanks!!!!
blac94Z
Mar 6, 2015 07:55 AM
blac94Z
Mar 2, 2015 06:03 PM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
