Heater making buzzing noise
Old Dec 5, 2002 | 09:37 AM
stew w/00&92's Avatar
When I use my heater it makes a buzzing noise coming from passenger side.It gets louder the higher I turn it up.Is this normal or should I have it checked?
Old Dec 5, 2002 | 10:02 AM
V6toZ28's Avatar
Similair thing happend on my V6 and on my Z. In both cases it was just leaf that had been sucked up into the fan ... eventually it will disintegrate and the noise will go away - takes about a month.
Old Dec 5, 2002 | 11:40 AM
Ken S's Avatar
ahhh.. that explains it.... I had the same symptom a while back and it disappeared too..
Old Dec 5, 2002 | 12:14 PM
2001NBMZ28's Avatar
Same thing happened to a friend of mine. He removed the passenger side underdash cover exposing the motor, removed the screws holding the motor up, reached in and pulled leaves out.
Old Dec 5, 2002 | 12:18 PM
bbentley40's Avatar
The motor? You mean the motor for the heater blower? Mine is doing it now too so if I can remove some leaves to fix it that would be great!!
Old Dec 5, 2002 | 03:02 PM
1badLS1M6's Avatar
Mine was whistling as well for about a month after i got it and then it just went away. It was very aggravating, so hopefully it wont happen again.
Chris
Old Dec 5, 2002 | 03:04 PM
Thanks,I have a huge tree over my driveway.Leaves fall right on cars.I'll just wait for it to go away.
warmeck
Mar 22, 2015 10:28 AM
Jan 23, 2015 01:13 PM
Rod Bender
Jan 1, 2015 03:18 PM
pologreen97z
Dec 2, 2014 10:42 AM
Dave19yz28
Jan 26, 2003 01:45 PM
