rear main seal
Old Oct 26, 2007 | 06:54 PM
Garcia95's Avatar
rear main seal
hey guys i have an oil leak problem from the rear main seal of my 95 3.4 camaro. the rear main seal was replaced in may and it now leaks more oil than before. my dad said that its probably the crankshaft thats out of round at the rear of the engine. what could it be. any ideas will be good thanks.
Old Oct 27, 2007 | 10:42 AM
Robert 98's Avatar
rear main leak
Are you 100% sure it's the rear main? It could be your lower intake leaking at the back, get under the car and feel around up above the starter area and see if ther is any oil there, I had a 95 with the 3.4L and I thougt my rear main was leaking too, but it turned out to be the intake
Old Oct 27, 2007 | 02:28 PM
Garcia95's Avatar
well i had not thought of that
thanks i will look into that as soon as i get out of work
thanks for that info
Old Oct 29, 2007 | 08:18 AM
Garcia95's Avatar
u know i checked that and its a big oily mess down there its hard to tell where its coming from.
Old Oct 29, 2007 | 08:48 AM
Robert 98's Avatar
Yeah, thats the way mine was, I took the cover off off of the tourqe converter and would have sworn it was the rear main seal but it wasn't anyway I would do some more checking, I hope this helps you out some,
Robert
Old Oct 30, 2007 | 12:40 AM
Garcia95's Avatar
thanks man i will do that as soon as i have a chance
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
BigWil
Mar 29, 2015 12:24 PM
carl.froehlich
Mar 13, 2015 12:38 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
