Viper T56???
Old Dec 5, 2002 | 02:55 AM
InjectedSS's Avatar
Viper T56???
well my buddy is gonna sell his viper and i talked him into letting me swap him trannys anyways im wondering if it will fit.... i know its the same tranny but im thinking the input shaft will be different as with the LS1 T56 being different.... i guess the LS1 t56 is the tremec t56 and the lt1 id the borg warner right?
thanks guys
Old Dec 5, 2002 | 04:08 AM
GhostZ's Avatar
MOTHER OF GOD!
They're both Borg Warner bish.
And from everything I've just done a search on, they are the same.
Found a couple of pages where they used the Viper T56 in an LT1 bell housing and bolted it up to the Camaro....didn't see anything about different sized input shafts though.
Old Dec 5, 2002 | 06:55 AM
IDOXLR8's Avatar
The viper tranny is not a direct bolt-on. Contact D&D performance. They currently offer a bellhousing that will allow you to use a viper tranny. THe input shafts are different on the F-body and Viper
Old Dec 5, 2002 | 08:14 AM
CANTONRACER's Avatar
A bud of mine is using a Viper input shaft with his f-bod M6. Did some machine work to get it to work.
Old Dec 5, 2002 | 08:24 AM
Atilla_95_Z28's Avatar
From: As close to Kentucky as I can get and not actually live there!
Did you guys see the new Super Chevy special Chevelle magazine where some guy out a T56 out of a Viper into a 70 SS Chevelle. He also put a 502 in just for fun!
Old Dec 5, 2002 | 12:18 PM
InjectedSS's Avatar
Originally posted by GhostZ
MOTHER OF GOD!
MOTHER OF GOD!!!!!! WHAT UP BISH!!!
from what it sounds like they will bolt up just fine huh....just like the drag launch springs and shocks huh
Old Dec 5, 2002 | 12:21 PM
max929's Avatar
Let us know how the swap went.
Old Dec 5, 2002 | 01:11 PM
BUBBA's Avatar
My question is Why? If I was going to do something like that I would have to have a reasonable expectation of making an improvement.
Please tell me why.
Old Dec 5, 2002 | 01:20 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
bubba-
The viper T56 is stronger, features a larger output shaft.. among other things.
Old Dec 5, 2002 | 02:13 PM
Roadmaster's Avatar
I had a friend who once owned a 1994 Viper RT10. His car had low miles on it and he had to replace the tranny...
I have heard other stories about the Viper T-56's having mechanical troubles.
Maybe just bad drivers instead
Dustin
Old Dec 5, 2002 | 02:29 PM
BUBBA's Avatar
Stronger is good.
Since the viper has so much torque down low, I can see why the gear ratios and rear gears can be higher than our cars, but I wonder why higher gears would be more beneficial than those on the F-Body t-56? Just curious.
Old Dec 5, 2002 | 02:32 PM
Bubba- the gear ratios are the same.
Old Dec 5, 2002 | 02:41 PM
BUBBA's Avatar
Viper 1 2 66
2 1.78
3 1.30
4 1.00
5 0.74
6 0.50 Rear 3.3 (something like that)
Camaro
1 2.97
2 1.94
3 1.35
4 1.00
5 .84
6. .62
Rear 3.42
Am I missing something?
Old Dec 5, 2002 | 02:44 PM
yes, you are
you quoted a 93 T56, with the 3.23 rear end..(in an fbody)
the better, and more common 94+ T56(found in 94 and newer fbodies) is the same as the viper, and the car comes with 3.42s
there is another 93 T56 with an even steeper first.. closer to a T5.
Old Dec 5, 2002 | 03:08 PM
BUBBA's Avatar
Thanks Jordan.
