Series 2 Vs. Series 3
Old Oct 23, 2007 | 10:14 AM
94Camaro_Z_28's Avatar
How can I tell these two carriers apart? I have a posi carrier from a 94Z that doesn't have any gears on it and I need to know if it's a series 2 or series 3.
Old Oct 25, 2007 | 04:24 AM
Style's Avatar
do you have access to the 94 Z?
Do you know if it was a manual or can you check the build codes?
Old Oct 25, 2007 | 06:37 AM
Capn Pete's Avatar
Unfortunately, in all the time I've messed around with 10-bolt diffs, I've never actually taken the measurement of the distance from a flat surface, to the face of the flange that the ring gear bolts onto . That face is off-set by ~1/4" one way or another, depending on whether the carrier is a 2 or 3 series. That's the only difference (it allows for larger or smaller pinion gears, which is dependent on the high/low ratio).
As 'Style' already pointed out, if you know what car this came out of (specifically with reference to whether it was a 6-speed or an auto, and then if you happened to know what ratio it had, if it was an auto (2.73 or 3.23)). If it was a 2.73 auto, it's a 2-series. Otherwise, anything else and it's a 3-series.
UNLESS it came from a 3.08 geared V6 Camaro, in which case it would also be a 2-series .
Old Oct 28, 2007 | 02:30 PM
Nope, no access to the other car, that would be to easy.
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
NewsBot
Jul 3, 2015 02:10 PM
May 1, 2015 01:14 PM
