Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
corvette injectors
Old Oct 19, 2007 | 06:41 PM
96camaroz281988's Avatar
corvette injectors
i need your guys help i got some corvette injectors off ebay. the guy said they came off a z06 and that is all he does not now what year and I need to get the o rings for them and. the # on them are is 280155752 and they look like this
so if and you can till me like what years they came of and if they are even Z06 and also there is a little plastic o ring on the top part the goes in to the fuel rail that is broke can i still uses it or do i have to get a new one and if you guys need more pictures of them i can get more.
Old Oct 20, 2007 | 11:29 PM
That looks like the set someone was selling for $65.
http://cgi.ebay.com/ebaymotors/97-98...QQcmdZViewItem
The listing on eBay shows them as 97/98 Corvette injectors. They are actually Bosch injectors. The LS1's injectors had GM part #'s. The 97/98 Vette used GM 12554271, rated at 28.5 #/HR in a 58psi fuel system. The C5 Z06 engine used GM part 12561462, also rated at 28.5 #/HR. If the Bosch is in fact a direct replacement for the GM parts, it would likely have a similar flow rating. If you actually have a 96 Camaro Z28 with an LT1, they will actually flow slightly less (24.7 #/HR) than your stock injectors (24.9 #/HR) when operated at the stock LT1 fuel pressure of 43.5psi.
My reference table shows that injector as rated at 28.55 #/HR, but it does not show the pressure at which it was rated. I'd guess what you have is basically a stock rated LS1 injector, used in the models mentioned above.
Old Oct 21, 2007 | 11:49 AM
well this is for my father 95 formula he put a bigger throttle body on and he is putting some headers on and he has a high flow muffler so he got these injectors for free basically and he wanted to put them on. he is have the computer sent out and change for his stuff that he is putting on.
Old Oct 21, 2007 | 11:13 PM
He doesn't have to change anything in the computer.... they are the same size as his stock injectors. They will not improve performance in any way. "Free" doesn't make them a good buy.
KYWes
Jun 14, 2022 06:52 AM
whitehooptie
Jul 12, 2015 06:10 PM
mrwz28
Jul 8, 2015 09:11 PM
