Car goes in and out of gear easy when not running. PITA when running.
Old Oct 15, 2007 | 01:12 AM
MeanGreen97Z's Avatar
It's hard to get the car in and out of gear when it is running. When it is not running it slides in and out easily. Car is VERY hard to get in reverse at all times. I think I jacked something up when I pulled the cap from the hydraulic system. I took the diaphragm out to see the fluid level. I only started having this issue after. Think I need to bleed it?
Old Oct 15, 2007 | 03:31 AM
qa767's Avatar
I don't think that just taking off the cap to look at your fluid level caused any problems. I had the same problem with mine a few weeks ago. Hard to shift gears when running and it would grind going into reverse. I first tried bleeding the slave and master cylinders, no help. Replaced the slave and master cylinders with a GM unit, no help. Finally pulled the transmission and found that the problem was a destroyed pilot bearing. Good luck.
Old Oct 16, 2007 | 12:00 AM
Ya mine started this recently and I JUST did the mount right before it started acting crazy.
Old Oct 16, 2007 | 01:09 AM
Daniel6718's Avatar
drain and replace the fluid on the clutch fuid resavoir...if ytou ever dog oin your car i think you should at least replace whats in the resavoir once a month for good clutch petal feel
Old Oct 16, 2007 | 01:50 PM
Ya right now it looks like mud... dark and nasty looking.
Old Oct 16, 2007 | 03:12 PM
thesource2004's Avatar
Definately sounds like a clutch issue but you can damage the transmission if you drive it like that as well .
Old Oct 16, 2007 | 03:44 PM
Found a used LT4 clutch kit... Hoping to find a cheap pilot and throwout bearing.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
