Gen V GM V8s will be DOHC...???
Old Oct 1, 2007 | 03:27 PM
Threxx's Avatar
At least according to the following article the truck V8s at the very least will be DOHC
http://www.pickuptruck.com/html/news...eunionuaw.html
Which would tend to make me believe they might all be going OHC since the gen IVs are all part of the same family despite being in a car or truck.
Old Oct 1, 2007 | 03:36 PM
90 Z28SS's Avatar
GM has to be just a wee bit fumed the media has access to and is picking apart its product plans thru 2013 ....wow .
Old Oct 1, 2007 | 03:47 PM
Chrome383Z's Avatar
I'd say it's still way to far out for too much speculation.
Old Oct 1, 2007 | 05:10 PM
bossco's Avatar
"Up until this point, it’s been conventional wisdom that implementing cylinder deactivation on OHC engines is impractical for reasons of cost and complexity."
Seems kinda easy to implement on OHC valvetrains that use a cam follower and lash adjuster, just need to make the lash adjuster long enough so that when the cylinder is deactivated, the follower will drop below the lobe on the cam. I imagine that it would nothing for a compact head design, but this sort of OHC valvetrain seems to lend itself well to cylinder deactivation without unnessecary complication (while its a totally diffferent beast, BMW's vanos system is perhaps the poster child for a mechanically complex valvetrain - or maybe thats ducati????)
Old Oct 1, 2007 | 07:03 PM
Jim the Nomad's Avatar
What happened to those designs for a chevy engine with two cams in the block? that sounded really cool...
Old Oct 1, 2007 | 07:55 PM
posaune's Avatar
according to http://www.futureoftheunion.com/docs...er149pages.pdf only the 6.2 will be OHC. The Gen V 5X (I'm assuming the 5 is for 5.something liters) will still be OHV. Tons of engine and veice info starting on page 50.
Old Oct 1, 2007 | 07:59 PM
bossco's Avatar
Might have been a PITA? or didn't lend itself well to VVT or the like? Chrysler made a slick little system with its cam-n-cam for the new Viper, That would really be neat in a SOHC engine. OHC cam engines make it easy to implement VVT (especially DOHC) so thats maybe why they are considering going it, killer low and mid lift aside with relatively wimpy cam profiles.
Old Oct 2, 2007 | 06:35 AM
91_z28_4me's Avatar
It still holds the patents but may choose not to use them.
Old Oct 2, 2007 | 10:52 AM
Ken S's Avatar
I'm wondering if they figured out a way to physical package the cams up on top, to keep the engine's overall size similar to a pushrod engine of the same displacement.
I guess its possible.. Mercede's 6.2L DOHC V8 isn't much heavier than a LS7? Dunno about external size.
Old Oct 2, 2007 | 11:01 AM
91_z28_4me's Avatar
The LS7 is also packing a dry sump oiling system.
Old Oct 2, 2007 | 11:18 AM
96_Camaro_B4C's Avatar
I think AMG / M-B charge like $40k or more for that engine. That makes the already expensive (at ~$12k, IIRC) LS7 look like a screaming bargain).
Old Oct 2, 2007 | 12:09 PM
Ken S's Avatar
Yea, but IMO, GM's got a knack of making powertrain's cost effective. If there's any company that could do it, it would be GM.
Old Oct 2, 2007 | 12:24 PM
AdioSS's Avatar
West South Central Moderator
Compared to Chevy charging $25k for the LS7 over the LS3. You just get the bigger wheels/tires, CF body parts, etc for free
And I'm pretty sure the AMG 6.2L is dry-sump also.
David Dempsey
Mar 12, 2016 12:42 AM
jayblev95
Sep 26, 2015 09:44 PM
HAWG
Sep 25, 2015 11:41 AM
