Brakes make crunching noise
Old Sep 30, 2007 | 03:24 PM
Oxygen454's Avatar
Need help... when slowing down my brakes make a crunchy spring noise off and on... I believe the off and on might be due to warped disks...
When Im sitting at a stand still and press the brakes, there is a springy crunching noise. I took it to the local brake shop and they couldent figure it out. Any suggestions?
p.s. this started after putting new brake pads on, only happens to one side I believe pass rear. Maybe not lubing the slides? or rods w.e. there called?
Old Sep 30, 2007 | 03:40 PM
Oxygen454's Avatar
This is the noise my brake is making.... when pumping the brake...
http://www.cpdesignonline.com/brake_noise.wav
Old Oct 6, 2007 | 01:03 AM
Oxygen454's Avatar
Anyone have any ideas? Please?
Old Oct 6, 2007 | 08:09 PM
n2ceptor's Avatar
It sounds like a bind somewhere?????? If everything looks good, I would just remove, and clean all components..... Then use brake grease and lubricate the pad sliding areas....
If you are sure its on the rear, check the H-clip( #17 )....It might be bent/damaged..
http://shbox.com/1/rear_caliper.jpg
Picture courtesy of Shoebox.......
Old Oct 10, 2007 | 05:13 PM
Oxygen454's Avatar
Thanks for your help, will look into that. I didn't see a H clip before.
Fatdog2
Feb 12, 2015 12:24 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
Red97LT1
Aug 21, 2002 10:31 PM
