7.5 strength?
Old Sep 24, 2007 | 07:37 PM
Boostwhat's Avatar
7.5 strength?
I have a 95z28 weighing 2850 W/ driver with a fully forged 355 LT1 Nitrous motor. 420rwhp motor 600+ on n2o. The transmission is a Coan Pro-Street 4l60e w/ 3500 10" converter. The car will be on MT Drag radials or 28x10.5 Et Drags. The rearend consists of a auburn pro unit, motive 3.73's, c clip eliminators on stock axles, TA Cover, welded tubes, etc. Car should 60' high 1.3x's. How long will this thing live? Or should i sell it save and get a 12bolt? What do you think?
Old Sep 25, 2007 | 07:19 AM
teke184's Avatar
could blow on you first pass....could hold off till your 100th pass...
there is no definate answer.
are you making more power than the rear was designed to handle....YES
therefor its just a matter of time.
i'd sell it and get a 12bolt
Old Sep 25, 2007 | 10:37 AM
Daniel6718's Avatar
your cars lights but i dont think with 3.73 and a 3500 stall youll be able to get into the 1.3 range...
if you really want it to last then go back to 3.23 or 3.42 and leave on whatever you want...they are a lot less likely to break than 3.73
Old Sep 25, 2007 | 11:06 AM
96m6lt1's Avatar
the axles on these rears are not the big problem,its the small surface area of the ring and pinion.
since you are lookin for some serious 60' times you should get a rearend that will withstand
those launches.
Old Sep 25, 2007 | 11:34 AM
Daniel6718's Avatar
ive seen low 1.4 60' in a 3700 pound iroc carmaro with only a girdle and 3.23
Old Sep 25, 2007 | 11:50 AM
sn8ke eatr's Avatar
these rears are a crapshoot. some of them break with a stock car, some live deep into the 10's... id say run it till it blows then buy a good rear
Old Sep 25, 2007 | 09:55 PM
gota406's Avatar
Do you play the lotto
I stripped the ring gear with my 4.10 gears. The lower the gears, the fewer teeth are engaged at once. Thus the 3.23/3.42 comment above. Good luck.
Old Sep 27, 2007 | 06:39 AM
mook99TA's Avatar
Don't put any more money into the 7.5 just wait for it to break and then get a 12 bolt or a 9in. Had one buddy buy DR's on a almost stock LS1 and blew his rear out on his second pass and others that are still running a total stock rear in the 1.5-1.7 range. I am still running my stock rear and haven't had any problems. My advice is just to not put any money into and start saving for the day it does blow.
Old Sep 27, 2007 | 08:37 AM
wrd1972's Avatar
Holy crap that is light.
Old Sep 30, 2007 | 11:20 PM
Compstall's Avatar
His setup might just last longer than you think at that weight. Ya never know though. I have seen everything already mentioned here as well. Mine is still holding up after 220+ passes down the strip, autocrossing, road racing, and plenty of spirited driving in between...
karpetcm
Aug 14, 2015 03:02 PM
blmw
Jun 14, 2015 05:20 PM
Apr 16, 2015 09:57 AM
mongoose=
Mar 22, 2015 07:22 AM
Lonemechanic
Feb 19, 2015 10:29 AM
