Datamaster trans logging question
Old Sep 1, 2007 | 06:48 PM
MichiganSkip's Avatar
Anyone log trans activity when running Datamaster? I need to know what the "Slip RPM" is. And how it should look compared to the engine's rpm.
Skip in MI
Old Sep 3, 2007 | 09:00 AM
aifilaw's Avatar
slip rpm is the difference between the input shaft of the transmission and the output shaft.
when the torque converter is stalling then this will be a high number as the engine will be turning quickly and the tail shaft will not. When you are decelerating it will be a negative number, and when the torque converter is locked it will vary around -10 to +10 more or less TCC DC is never right, so I go by when the converter locks by the slip RPM.
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 13, 2015 09:52 PM
Lederman1976
Nov 30, 2014 05:21 AM
2_shady
Jun 30, 2002 11:24 PM
