rear end question
Old Aug 25, 2007 | 10:42 AM
Sunsetmaro's Avatar
Cool rear end question
Hello. I was wondering whats the lowest, safest gear possible for the gm 10 bolt rear, without having to worry about screwing the rear end up. I was told that the 10 bolts are pretty weak and I was thinking of installing 3.90's or 3.73's. Don't camaro ss have 3.73 or 3.42? Would I be safer to jump from my stock 3.23 to a 3.42 and will I see a big difference? Let me know. I was told the higest I could install for a proper mesh would be the 3.42's, but I don't think so. Let me know if 3.73's would work.
Old Aug 25, 2007 | 10:51 AM
94_PatriotRed_Z's Avatar
Many people run 4.10s, or 3.73s. The biggest gear stock is 3.42s in a z rated M6.
Old Aug 25, 2007 | 12:18 PM
karpetcm5's Avatar
If your going from 3.23's then you have an A4. You can go with 3.73's as far as breaking them it all depends some people have some luck and some dont. The stickier your tires most likely you will break something. I had a 01 SS 6speed with 4.10's installed broke them twice with nitto drag radials. I have 4.10's in my 93 Z with nitrous just street tires and its fine, but then again i dont get on it much.
oldschool
Feb 9, 2016 09:21 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
