New List of SES Codes...
Old Aug 24, 2007 | 05:56 PM
Phantomhp's Avatar
Well got my PCM flashed and is now correct so now I am getting 3 codes.
53 for high system voltage
59 for tranny fluid temp sensor circuit high - low temp
81 for QDM or shift B solenoid fault
So any ideas on the 59 and 81 codes? or could these be caused by the high voltage code?
Thanks!
Old Aug 24, 2007 | 06:40 PM
59 Transmission Fluid Temperature (TFT) sensor circuit high (low temperature indicated)
81 Transmission 2-3 shift solenoid circuit
Check the transmission electrical connector to be sure it is on tight.
Old Aug 24, 2007 | 09:12 PM
Phantomhp's Avatar
Would both of those be caused due to the fact I have a 97 transmission and a 94 harness/pcm?
Thanks!
Old Aug 24, 2007 | 10:36 PM
Possibly, but I am no tranny expert. I know the 95-97 uses a PWM TCC solenoid that the 94s don't, so how are you getting around that?
Old Aug 25, 2007 | 10:36 AM
Phantomhp's Avatar
That part I have no idea about. Unfortunatly I bought the car this way as the previous owner as I found out didn't know there was a difference between the drivetrains.
I will just put up a thread in the tranny section on those codes and see what some of the sponsor or others say about it.
Thanks!
Aug 24, 2015 06:41 AM
Highlanderrtl
Jul 24, 2015 03:34 AM
Jul 17, 2015 02:47 PM
Jul 10, 2015 02:23 PM
CARiD
Jul 7, 2015 08:19 AM
