think i lost o/d
Old Aug 21, 2007 | 07:48 PM
er-z's Avatar
think i lost o/d
i think i lost 4th gear ,it seams to shift 1-2-3-4 but my rpms are way to high for my gears (2.73 ) i trun about 1900 to 2000k rpms at 55-60 .by the chart on http://www.f-body.org/gears/ i should be at 75-80 mph in 4th at said rpms . what things should i look for that could be wrong .trans a stock 95 4l60e
Old Aug 21, 2007 | 08:23 PM
showstoppers-96-Z/28's Avatar
if it seems to be shifting fine i wouldnt look at the trans. I'd check to see if those gears have ever been replaced before. Those sound like the 3.23 gears like i used to have. I now run 3.73's, so its quite different. But unless you've owned the car from day one, id look into that issue.
Old Aug 21, 2007 | 08:40 PM
er-z's Avatar
idk about the gears being changed it was all stock when i got it . all shifting is frim and dead on (no slipping i can feel ) but it does not feel like there a 4th gear. it fells like it shifts but it doesn't .
Old Aug 22, 2007 | 05:35 AM
Gun5's Avatar
hey as long as your tranyn does 3 drops its working, halfway get on it and see if it goes 1-2-3-4.. also go beside a buddy going 60 maybe yall will be going different speeds? meaning gear change with no tune throwing ur speedo off
blac94Z
Nov 4, 2015 01:59 PM
WobblySausage
Oct 7, 2015 02:44 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
HAWG
Sep 25, 2015 11:41 AM
