fan question
Old Aug 13, 2007 | 03:58 PM
Syn's Avatar
Syn
fan question
well i'm trying to figure some things out, but i know theres 2 fans on the ls1 is one only for the a/c? or are both used to cool the motor, also if only one is used how could i get both to run, i want to put in a fan switch since i am going to the woodward dreamcruise (big car event lots of bumper to bumper traffic) and i dont want my car to over heat.
on my other cars i just simply grounded the relay to turn the fan on, should i do the same with my z?
thanks
Russ
Old Aug 13, 2007 | 04:22 PM
2001NBMZ28's Avatar
Both fans operate at either low or high speed depending on their settings. Overheating in bumper to bumper traffic shouldn't happen if the cooling system is OK. If you're just wanting to install a switch SLP sells one or you can wire one yourself - saw a link for a DIY switch w/leds earlier today, will find it and post it if you need it.
Old Aug 13, 2007 | 04:30 PM
Syn's Avatar
Syn
well this cruise is backed up you seriously move maybe 3-5 mile every 30-45mins
a fan hookup would be nice
Old Aug 13, 2007 | 04:38 PM
2001NBMZ28's Avatar
www.xious.com/camaro/install-fanswitch.html Haven't tried this myself, I have the SLP switch.
Old Aug 13, 2007 | 05:42 PM
Syn's Avatar
Syn
all the work for just that, i am gonna get out my wireing diagrams i forgot i had and just ground one relay so they make the fans stay on high, i dont think low speed is gonna be needed.
but thanks for the link this will help
Old Aug 14, 2007 | 05:42 AM
AL SS590 M6's Avatar
Moderator
You really don't need to do that. An LS1 will idle in the heat all day long without overheating. Ans yes I've been to the Dream Cruise so I know the conditions that you'll be in.
Last Thursday we spent 45 minutes going 4-5 miles in a traffic tie up on I-270 in St. Louis, MO in 100° heat with the air on. The temp guage hardly moved.
Old Aug 14, 2007 | 11:25 AM
johnny6's Avatar
The LS1 cooling system is a beast, especially with the 160 stat and re-programmed fans
Old Aug 14, 2007 | 11:43 AM
Marc 85Z28's Avatar
As long as the cooling system is in good working order (no leaks, damaged/missing air dams, etc) you can idle all day with the AC on in 100 degree weather in heavy traffic.
Old Aug 14, 2007 | 12:38 PM
SSpdDmon's Avatar
As stated, you should be fine.
Low speed fan turns on/off @ 226*F/219*F.
High speed fan turns on/off @ 233*F/227*F.
Low speed fan will turn on when A/C is on and ECT is greater than 32*F.
High speed fan will turn on when A/C is on if A/C system pressure becomes greater than 1710kPa (248psi).
The PCM has you covered.
Old Aug 14, 2007 | 05:04 PM
Syn's Avatar
Syn
well alright then i was just gonna taken a precautious measure, i have the royal purple purple ice in there too its suppose to keep the temps down as well.
i just wanted to be cautious
thanks guys
Magenta_Hearts
Mar 29, 2017 08:54 PM
linz
3rd Gen / L98 Engine Tech
Apr 7, 2015 11:49 AM
ChrisFrez
Mar 1, 2015 01:33 PM
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
