Help Locating Power
Old Aug 8, 2007 | 05:08 PM
ryentee's Avatar
Help Locating Power
I have searched the audio section for the last hour and think I have confused myself more than when I started. I have a 95Z and am going to install a new HU, amp and component set.. My car has the factory BOSE system but I am just bypassing all of that. My question is locating the best spot for tapping into the constant power, switched for the amp turn-on and ground. I also have a power antenna and need to know if that should just be attached to the switched power or some other way. Any help would be appreciated. Thanks!
Old Aug 9, 2007 | 12:06 PM
valter's Avatar
I am not sure I understand the question, but I'll try to answer New HU will have an output to turn on your amp and operate power antenna. Ground of the amp - closest chassis bolt. Amp power - you want to run a separate FUSED wire from your battery through a firewall and to your amp.
For connecting HU - search for pinout diagrams on internet.
Old Aug 10, 2007 | 08:57 AM
ryentee's Avatar
Thanks! All figured out
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
siguy
Nov 27, 2014 10:07 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
XtremeLt1
Sep 13, 2002 08:50 PM
