Car Lurching under WOT
Old Aug 8, 2007 | 03:36 PM
aaron1987's Avatar
As the title says recently I've noticed my z28 will occasionally lurch under WOT acceleration as if I'm letting on and off the accelerator despite it being floored, i've only noticed it in 3rd gear and above and generally above 3k rpms. Any thoughts on what could be going on? It's stock save a catback and CAI.
Old Aug 10, 2007 | 06:26 AM
CALL911's Avatar
Possibly a loose throttle cable? If you want to know for sure if the throttle is actually at 100% WOT, try having someone with a diagnostic cable and a laptop with LT1 edit, or tunercat ride with you on a run to see if the car is actually reading 100% WOT. That will at least help you narrow it down.
Old Aug 10, 2007 | 01:45 PM
soontobeGN's Avatar
just a guess, but check your fuel filter, if it is very clogged it may not be allowing enough gas to get to the motor for those WOT bursts. again, purely an educated guess, not based on anything other than that.
jayblev95
Jan 20, 2015 01:30 PM
Jazsun
Dec 29, 2014 12:14 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
