Front Bilstein Question
Old Aug 7, 2007 | 10:49 AM
ss7's Avatar
ss7
Hello guys, I got a set of SLP Bilstein's today. And one of the front shocks came without the metal thing (dont know what its exactly called), nut and a washer. It can be seen on a pic
My question is, do I need it to install the shocks? Or can I reuse the one from OEM shocks, if there is one? Or if not.... where can I get replacement?
Thanks a lot for any help.
Old Aug 7, 2007 | 11:51 AM
Bow94z's Avatar
Well, where did you get it them from? SLP directly? Call and ask why it's not in the package
Old Aug 7, 2007 | 01:08 PM
ss7's Avatar
ss7
No, I got them from one of the guys on forums.
Old Aug 7, 2007 | 03:57 PM
Koby's Avatar
I installed those on my car, and quite truthfully I can't even tell you what those are for. I put them on mine since they came with the shock, but I don't see any function to them so you should be fine running without them, or without one.
Old Aug 7, 2007 | 07:56 PM
ss7's Avatar
ss7
Thanks for the reply. So that circle plate is not necessary for the install? All I have to find is nut then... I hope it is so.
Old Aug 7, 2007 | 09:12 PM
Bayer-Z28's Avatar
It slips on the top of the shock itself.... on here...
No idea what it's for either.. You may be able to use the one of the stocker, but I think that one is to small.
Old Aug 7, 2007 | 11:43 PM
ss7's Avatar
ss7
Thanks bayer, I hope its not one of those little things that make a big difference...
Old Aug 8, 2007 | 05:16 PM
Bayer-Z28's Avatar
I honestly didn't see a use for it myself, but I installed it anyway... Injuneer probably knows.. Waiting for him to chime in.. I'm curious too.
Old Aug 9, 2007 | 12:07 AM
ss7's Avatar
ss7
Just noticed that Koni's have plain metal circle plate.
So Im wondering if stock shocks have any plate/seat at all?
Old Aug 9, 2007 | 01:44 PM
ss7's Avatar
ss7
Went to a mechanic I know today, he said the main purpose of it is to protect the seal of the shock. Sounds about right.
Old Aug 9, 2007 | 02:31 PM
Ultra_Dog's Avatar
There's something important about the Bilsteins. Check the part numbers. When SLP made the Bilstein Level II suspension package for the 96/97 SS, they put Eibach springs on it, which lowered the car. They then went to Bilstein for the shocks. Those shocks are not the same shocks for a regular LT1 due to the spring height. The Bilstein shocks in the L2 package are of shorter height and have different valving/rebound.
Not sure if those are applicable, as shown in your picture.
Old Aug 9, 2007 | 05:54 PM
ss7's Avatar
ss7
Ultra_Dog, I got Pro Kit as well going in the car along with Bilstein's. Should it still be a problem? Gonna look up the part # when I get home. Thanks for the info.
Old Aug 9, 2007 | 09:43 PM
Bayer-Z28's Avatar
^ The bilstiens aren't really the greatest choice for the Pro Kit. The spring Rates aren't really the best. If you are doing the Pro Kit, contact Strano to have a set of shocks revalved for your specs... or just get the Koni's...
Old Aug 9, 2007 | 10:45 PM
It seems like a formidable piece to leave out. I would be uneasy about doing so. Even the stock shock has a thick piece there. I don't know if you could transfer that piece to the Bilstein.
Old Aug 10, 2007 | 09:39 AM
ss7's Avatar
ss7
Thanks guys, I'll try it with the stock if I dont find other way out, hope it will work. I've been dying to put the new shocks/springs in my car. And now that I have them it's the only thing that stopping me.
