Options for retarding timing with nitrous
Old Aug 5, 2007 | 09:56 AM
exgmguy's Avatar
I know most of you guys like the Mallory 685, but what other options are out there? It looks like if you already have an MSD 6a, 6al, etc... you can add an adjustable timing retard module to it.
I have a new Mallory 6A (virtually the same as MSD) sitting in my garage that I could use to start with.
Thanks,
Rob
Old Aug 5, 2007 | 10:33 AM
pyro719's Avatar
You would be better off selling it and getting a 685. It has everything you need in one box.
Old Aug 5, 2007 | 11:36 AM
97 RedSS's Avatar
I have the Digi 6 and it has everything cept window switch...like he said above, the 685 has everything in one box...
Old Aug 5, 2007 | 12:40 PM
exgmguy's Avatar
I am cheap and don't really want to spend close to $300 for one.
I know, I know......
Old Aug 5, 2007 | 02:04 PM
2000GTP's Avatar
I got my Mallory box from Summit for around 220 at the time. Also, if you add the cost of the MSD box and timing retard box together, it will be well over the cost of the Mallory box and you still would have to pick up a window switch as well, which the Mallory also has as a built in feature.
Old Aug 5, 2007 | 02:39 PM
69z-28's Avatar
mallory 685 really is **** and beer. has EVERYTHING. once you wire it up how you want it, your good to go and everything is at your fingertips. i love it!
Old Aug 5, 2007 | 04:38 PM
CamaroSS30thAnn's Avatar
get the 685
going cheap with nitrous is like buying HD without an HD TV
not but really going cheap with N2O will cost u more in the long run on a rebuild
Old Aug 5, 2007 | 04:49 PM
LT-x7's Avatar
The 685 really is the cheap way out. I don't understand why everyone runing nitrous (or boost) isn't running one.
Old Aug 5, 2007 | 05:00 PM
cjmatt's Avatar
crane trc-1 is cheap...only like 150
Old Aug 5, 2007 | 05:20 PM
LT-x7's Avatar
But all it does is retard timing right?
For $70 more with the 685 you get:
Rev limiter
2-step
Window switch
start retard
Old Aug 5, 2007 | 06:13 PM
exgmguy's Avatar
The Crane TRC-1 is listed for Ford's and Honda's. I could not dig up much info on it.
Old Aug 6, 2007 | 09:35 AM
Ray@NitroDaves's Avatar
The 685 is a good box for someone who needs something that can do it all. But may not be right for other end users. It will all depend on what the needs of the customer are.
If you already have an ignition box most companies have an add on retard module.
I am running the MSD Digital 6 and a progressive controller. The 685 would not be right for my application as I needed a box that could control multiple stages and give me delay and ramp abilities.
Old Aug 11, 2007 | 08:10 PM
97SS0594's Avatar
i have the mallory hyfire VI (aka the 685) and i love it. id suggest getting one.
Old Aug 11, 2007 | 08:32 PM
exgmguy's Avatar
I just bought a 685 from a guy on this board. Sweet.
Old Aug 12, 2007 | 11:03 PM
JodyJ's Avatar
Since you already have the Mallory 6A, I would consider the FJO mini progressive controller: http://www.nitrousoutlet.com/catalog...product_id=952
Jody J.
