TPS%vsVoltage
Old Dec 1, 2002 | 12:44 PM
WP's Avatar
WP
Question TPS%vsVoltage
Trying to locate a full throttle shift problem that rectifies itself after shutting the engine down then restarting it,I discovered that the TPS% scale runs smothly up to 100% then hits 4% and remains there untill the engine restarts?,TPS signal voltage seams to be normal even when stuck at 4%(no wonder I'v got full throttle shift problems),I've already replaced the TPS sensor but this did not help,I was wondering if this a programing issue or what?.
Old Dec 1, 2002 | 06:27 PM
drop top steve's Avatar
Check the wiring harness, if that looks good, try a different pcm or a reflash of the one you have. I'll bet it's a bad pcm.
Old Dec 1, 2002 | 09:04 PM
WP's Avatar
WP
Already tried a different pcm but w/a different tune!,sure beats the hell out of me,why? after reaching 100% the tps hits 4% and stays stuck untill a restart,the unusual thing is volatage signal from the tps works normaly even at the 4%stuck level,unusual right???.
Old Dec 1, 2002 | 11:51 PM
Dan K's Avatar
So...after whatever datalogger you're using says 100% TPS and TPS voltage is reading correct for WOT (4.5 or whatever)....it then just magically drops and sticks at 4% even though the voltage is OK?
I don't think it's possible that it's a programming issue...not sure how programming would affect that.
I would think that as long as the voltage is OK that it's not really a TPS problem either. I don't think the computer uses a value for TPS%...that's what the voltage signal is for. The TPS% is just so your datalogger can show you how far the throttle is open.
Old Dec 2, 2002 | 09:47 PM
How are you logging data, or what scan tool are you useing. It could be a lodding issue. Strange deal, if tps v changes, then % readig should chamge.
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
4586
Aug 18, 2015 07:08 AM
