Good lca's?
Old Jul 30, 2007 | 04:09 PM
bombebomb's Avatar
Good lca's?
Im going to buy some lower control arms and was wondering what all I would need, and where I can buy some good ones online. Thanks.
and after reading a post on the same page im already on I found this post
http://web.camaross.com/forums/showthread.php?t=531888 Im thinking about getting these
http://store.summitracing.com/partde...130+4294839061 Are these good, and what else do I need to install these, I have stock ride height. Also are the more exspensive ones really make any difference?
Old Jul 30, 2007 | 04:36 PM
93v8clone's Avatar
go with spohn all the way parts are excellant and good people to deal with hell take care of ya
Old Jul 30, 2007 | 04:37 PM
bombebomb's Avatar
Also, what is the relocation bracket for exactly?
o spohn is not that much more exspensive, I thought they was 200$ or more from there, I think ill go with spohn after all. What all will I need?
Old Jul 30, 2007 | 04:46 PM
2000GTP's Avatar
The non-adjustable Spohn arms will run around the same. I would also replace the LCA mounting bolts while you are at it. I'm sure the old ones are going to be pretty rusted by now.
Old Jul 30, 2007 | 04:56 PM
bombebomb's Avatar
And once again 2000GTP is here to save the day should I buy the relo brackets while im at it?
this is what I got in the cart
Lower control arms-boxed with poly bushings
Lower control arm relocation brackets
LCA mounting hardware kit
Old Jul 30, 2007 | 04:57 PM
rexcellent's Avatar
The relocation brackets are mainly for people who have lowered their car. It places the end of the LCA that is attached to the axle lower so it keeps the correct geometry as it did before you lowered it.
Old Jul 30, 2007 | 05:09 PM
bombebomb's Avatar
So I should not get relo brackets since my car is not lowerd?
Old Jul 30, 2007 | 05:39 PM
2000GTP's Avatar
People have still posted some traction improvements with relocation brackets, even at stock ride height.
Old Jul 30, 2007 | 06:07 PM
bombebomb's Avatar
Ok, thank you looks like ill be buying them, so I got everything I need correct?
LCA
LCA relocation bracket
ordering tonite if this is all i need
Old Jul 30, 2007 | 06:10 PM
2000GTP's Avatar
List looks good to me.
Old Jul 30, 2007 | 06:48 PM
hotpart's Avatar
Former Vendor
What are your plans with the car? There are many different control arms available that serve different purposes so to say a certain control arm is best for your needs is really mis-leading without knowing how you want your car to perform. A little more detail on your plans would be great. Example - do you want to go around corners, autocross, road race, drag race, or just an everyday street driving and just looking to improve something you currently don't like about the feel of the car?
Old Jul 30, 2007 | 06:55 PM
bombebomb's Avatar
Mostly drag race use, ill be driving it everyday, but I want it set mostly for drag racing.
Old Jul 30, 2007 | 07:15 PM
Bud M's Avatar
I would not get the Lakewood arms, the Hotpart arms are better for handling and should be just as good for straight line
Old Jul 30, 2007 | 07:22 PM
bombebomb's Avatar
Im not getting the lakewoods now, I thought most lca's were 200ish $ but I found out there not.
Old Jul 30, 2007 | 07:59 PM
CustomSSI's Avatar
UMI's are about $100 and LCA brackets are well worth the money.. lowered or not.. They will run you about another $100 installed ($60 bracket $40 weld in install)
