Good lca's?
Im going to buy some lower control arms and was wondering what all I would need, and where I can buy some good ones online. Thanks.
and after reading a post on the same page im already on I found this post http://web.camaross.com/forums/showthread.php?t=531888 Im thinking about getting these http://store.summitracing.com/partde...130+4294839061 Are these good, and what else do I need to install these, I have stock ride height. Also are the more exspensive ones really make any difference? |
go with spohn all the way parts are excellant and good people to deal with hell take care of ya
Also, what is the relocation bracket for exactly?
o spohn is not that much more exspensive, I thought they was 200$ or more from there, I think ill go with spohn after all. What all will I need? |
Originally Posted by bombebomb
(Post 4771117)
Originally Posted by 2000GTP
(Post 4771147)
The non-adjustable Spohn arms will run around the same. I would also replace the LCA mounting bolts while you are at it. I'm sure the old ones are going to be pretty rusted by now.
this is what I got in the cart Lower control arms-boxed with poly bushings Lower control arm relocation brackets LCA mounting hardware kit |
The relocation brackets are mainly for people who have lowered their car. It places the end of the LCA that is attached to the axle lower so it keeps the correct geometry as it did before you lowered it.
So I should not get relo brackets since my car is not lowerd?
People have still posted some traction improvements with relocation brackets, even at stock ride height.
(Post 4771328)
LCA LCA mounting hardware kit LCA relocation bracket ordering tonite if this is all i need |
List looks good to me.
What are your plans with the car? There are many different control arms available that serve different purposes so to say a certain control arm is best for your needs is really mis-leading without knowing how you want your car to perform. A little more detail on your plans would be great. Example - do you want to go around corners, autocross, road race, drag race, or just an everyday street driving and just looking to improve something you currently don't like about the feel of the car?
Originally Posted by hotpart
(Post 4771486)
I would not get the Lakewood arms, the Hotpart arms are better for handling and should be just as good for straight line
Im not getting the lakewoods now, I thought most lca's were 200ish $ but I found out there not.
UMI's are about $100 and LCA brackets are well worth the money.. lowered or not.. They will run you about another $100 installed ($60 bracket $40 weld in install)
