Is it safe to boost...
Old Jul 26, 2007 | 09:47 PM
wrd1972's Avatar
Check out my sig, my CR is 11.2 with about 400 RWHP.
Is it safe to lightly boost my engine or will I blow things up. I am thinking 5-6# or so.
Old Jul 26, 2007 | 09:57 PM
Kredz28's Avatar
At 11.2:1 with a cast piston, they will break in a matter of time
Old Jul 27, 2007 | 09:27 AM
wrd1972's Avatar
I have mahle forged pistons, is that a cast pistion?
Does that make a difference?
Old Jul 27, 2007 | 09:33 AM
OBE1 95Z28's Avatar
A forged piston is much stronger than a cast piston.
Typically you want to reduce the compression ratio of the engine when going to a forced induction setup. 11.2 is a high compression ratio which will be much harder to keep the engine out of detonation on pump gas (91 - 93 octane). Detonation will destroy your engine over time.
Old Jul 27, 2007 | 09:41 AM
CrazyLT1's Avatar
Your compression ratio is more set-up for spray. So I would just get some n20 if you want more power now...
If you really want boost - you should AT LEAST get your compression down to the mid 9's
Old Jul 27, 2007 | 12:34 PM
wrd1972's Avatar
Nuff said,
Thanks guys. I currently have my rings gapped too tight for n2O. Oh well.
Old Jul 27, 2007 | 05:31 PM
Boosted_Z28's Avatar
Unless you are running some extreamly tight ring gaps, a 100hp-150hp shot would probably work out just fine. A stock LT-1 will survive this kind of spray, providing you take the necessary safety measures.
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 24, 2015 11:04 PM
Aug 7, 2015 08:52 AM
Jul 10, 2015 02:23 PM
Jan 23, 2015 01:13 PM
