Biggest tire on stock rim?
Old Jul 22, 2007 | 07:12 PM
bombebomb's Avatar
Im going to buy a set of nitto 555R's and was wondering how big I could go on stock rims? I dont know much about fitting on rims and how big a tire can go on, I know I can only fit 16 inch tires, but how wide?
Old Jul 23, 2007 | 08:43 AM
Nitto only makes one size 16" tire in the 555R drag radial, so the only choice you have is 245/50-15.
http://www.nittotire.com/#index%2Etire%2Ent555r%2Esizes
Old Jul 23, 2007 | 08:53 PM
Garcia95's Avatar
no 16 of any kind
Old Jul 29, 2007 | 12:06 PM
bombebomb's Avatar
So the p245/50R/16's will fit my stock rims (rear ones only)
Also while were here, how is haveing different size tires on the front, and back going to very my speedo?
Old Jul 30, 2007 | 01:53 PM
245/50-16 is a stock tire size (Z-rated option) on the stock 16x8" wheels. Only the rear tire diameter affects your speedo. As noted, for V8's with the Z-rated tire option, 245/50-16 is the stock size, so it won't affect the speedo. If you had the base tires (235/55-16), the 245's will cause your speedo to read about 2% higher than actual speed. PCM can be programmed for the tire size.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
Jason Short
Jan 19, 2015 06:33 PM
siguy
Nov 27, 2014 10:07 AM
