What Actually Locks Up the Converter?
Old Jul 20, 2007 | 10:32 PM
WestCoast96Z28's Avatar
What parameters actually trigger the computer to lock up the converter? Is it based on throttle position, speed, RPM, what gear you're in, or a combination of all these things?
I know it's good to be locked up at high speeds to save on gas mileage, but what's the benefit of the TC not locking up?
Old Jul 21, 2007 | 08:42 AM
exgmguy's Avatar
An unlocked converter allows torque multiplication. A locked converter is like a stick car at that point. No slippage.
Think of a converter as kind of a go kart clutch.
Lock up decided by a few different factors. They lock up in 3rd and 4th gear only. They unlock if you touch the brake pedal or give it 60% thottle or so. I think that some cars will not lock up until the engine reaches a specific temp????
Old Jul 21, 2007 | 10:40 AM
Performabuilt's Avatar
Supporting Vendor
Throttle position/speed/rpm/maf/engine temp all play a role in when the converter locks.
Old Jul 23, 2007 | 02:16 PM
I'd like to keep my converter unlocked in 4th at low speeds. Right now, I "think" its locking up in 4th at very low throttle. With 3.73s, here's how car shifts at very low throttle...say in city streets driving slowly.
1-2 around 15 mph
2-3 around 25 mph
3-4 around 35 mph
Well, when my car hits 35mph, it shifts to 4th and then gets real sluggish. I "think" it's locking up. I can push the gas a good bit, and it'll "slip" and get moving, but there is a slight delay. Just enough if I was racing someone starting at 40mph...this would not be a good pause.
I've tried the touching brake thing and it does seem to unlock, but that's kind of a pain in the *** to tap the brake and then punch the gas.
If I reprogrammed the shift point so that the 3-4 shift would occur 5 o 7 mph higher, would that help?
Old Jul 23, 2007 | 03:28 PM
chief455's Avatar
The pro builders should chime in but - sounds like you want what an edit program ot shift kit/higher stall convertor will do. EDIT the torque lock up points, shift kit programms the up/down shifts, higher stall will allow that release while at lower mph and rpm
Victor Lamb
Aug 26, 2017 02:52 PM
guruerror
Jun 9, 2015 07:41 AM
CheckOutMyRoost
May 23, 2015 02:33 PM
