DTC 66 - ABS Motor
Old Jul 18, 2007 | 03:41 PM
Pdiminico's Avatar
DTC 66 - ABS Motor
Where is the ABS motor located? I know where the pump is located.
Old Jul 18, 2007 | 05:38 PM
What year, model, engine, etc? For the LT1, for example:
DTC 66 = A/C refrigerant pressure sensor circuit (open or shorted)
Old Jul 19, 2007 | 07:34 PM
Pdiminico's Avatar
According to the GM shop manual DTC 66 = Rear ABS motor circuit shorted to battery.
It's a 94 Z28 LT1. My shop pulled the code for me.
Old Jul 19, 2007 | 10:14 PM
Then you were reading the codes from the EBCM, and not the PCM, correct?
The ABS unit sitting on the drivers side fender includes the ABS solenoid valves, the ABS modulator/motor pack assembly, the brake combination switch and the ABS bleeder valves. The shop manual shows the details.
Old Jul 20, 2007 | 08:54 PM
Pdiminico's Avatar
You are correct regarding the EBCM. The shop manual does not discuss overhauling or replacing the motor pack. Is it possible to replacing the motor pack instead of the whole unit?
Old Jul 21, 2007 | 11:42 AM
Not sure. Might want to ask that question in the "Suspension, Chassis and Brakes" forum.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
dreamer1q
Aug 20, 2002 11:19 AM
