newbie needs help!
Old Jul 2, 2007 | 10:58 PM
jmp2204's Avatar
newbie needs help!
hi, i'm new here and am a new camaro owner(97 rs)i currently drive a xcab z-71 and wifey drives a van but we wanted something sporty (camaro)for occasional use.Here is my issues:
1. power window, passenger side. i searched here and read the shoebox link,input power to the motor and it's toast.which to get aftermarket or oem?
2.windsheild wipers,they park in the vertical position?????no relay??? just a fuse and an unfindable overload breaker(according to owners manual )anybody have experience on this?breaker location?
3. Originally a remote door lock/alarm packaged car but no remote came with the car....tried to reprogram a remote from a 2000 gm(looks identical to the one they show in the camaros owners manual) no go on the reprogram....any body have any ideas here....
thanks in advance jmp
Old Jul 4, 2007 | 11:41 AM
jmp2204's Avatar
Old Jul 4, 2007 | 12:43 PM
2001NBMZ28's Avatar
I'd get an aftermarket window motor from a local parts store, cheaper than OEM and usually come with a lifetime warranty.
Are you sure the remote is correct/battery good? Look up the FCCID# on the back at http://autotechs.com/fcc/fccidsearch.htm You can also try resynchronizing it - press and hold the lock and unlock buttons down simultaneously for a few seconds - should cycle the door locks and flash the parking lights.
Don't know what's going with the wipers....
Old Jul 4, 2007 | 01:36 PM
jmp2204's Avatar
thanks for the response! your remote link sorted that out quickly(wrong part# but found the correct one) .will do the aftermarket window motor(did not know if oem might be worse as it seems to be an issue with these cars).....and the wiper problem i just recently told is likely a tab on or around the wiper motor control arm that wears off and without it ,it sends the arms vertical to park! apparently a notable problem on many gm's ie vans etc.....i will pull it apart and if it turns out to be true will post pictures of it and a fix for those who may have future issues thanks again!
Old Jul 4, 2007 | 07:38 PM
jhthornley's Avatar
get a new window motor... shoebox's site shows how to replace it.
Vertical wiper bit... I read recently (on here) that some "tab" is broken... do a search on "vertical wiper" or something like that...
no clue on the remotes.
Old Jul 4, 2007 | 10:54 PM
jmp2204's Avatar
window motor done ,shoe box procedure used!
wiper, i took pictures but it's hard to see .......there is a spraque type clutch or similar on a spring loaded pivoting "dog" that catches the tab lost it's spring(luckily i found it where the motor sits) put it back on and now it works.....that tab i hae heard from 2 gm techs is very common....
remote previous link settled that and proper one was ordered! thanks for the reply
Z28countrymama
Jan 22, 2015 02:50 AM
ssz28
Apr 29, 2003 05:26 PM
greg biz
West North Central
Apr 25, 2003 01:00 PM
lastZ
Jan 12, 2003 05:29 PM
2000zee28
Jan 11, 2003 09:57 PM
