How much timing?
Old Jun 27, 2007 | 02:29 AM
CamaroGuy22's Avatar
How much timing?
I realize that to be completely accurate the vehicle should be put on a dyno. At this time a dyno tune is not possible. What is a good bet for how many degrees timing be advanced on a 94 Z28 with the following mod list: K&N FIPK, CSR E-Waterpump, Mac Headers, Magnaflow Catback
Old Jun 27, 2007 | 09:07 AM
wrd1972's Avatar
The general I always hear for LT1 is ~36 degrees.
Old Jun 27, 2007 | 04:13 PM
BlackScreaminMachine's Avatar
Ive pushed my car to low 40's on the dyno, datamaster proven, but then again you cant assume your car will run the same, you need a dyno....
Old Jun 27, 2007 | 04:47 PM
stereomandan's Avatar
40's total timing maybe. Don't be confused with the timing you enter in the tunercat or Lt1 edit tables, and what datamaster reads out. datamaster reads the extras 2-3 degrees of timing that are added on top of the tunercat or LT1 Edit tune.
I would shoot for 36 degrees at 95 and 100 kpa from 3500 rpm+, like wrd1972 said, and see how that does. Datamaster will read this out as roughly 39 degrees total timing advance. 36 degrees is 2-3 more than stock at those rpms and MAP kpa.
Dan
Old Jun 27, 2007 | 08:30 PM
@ 6,500 rpm limit on the motor @ 40 kpa it had 42.5 degrees in the extended spark advance vs rpm vs MAP, then from 90-100 it went to 37. Just checked the file. Datamaster peaked 42
Old Jun 28, 2007 | 02:52 PM
SSpdDmon's Avatar
Wow...I only run 28*~29* in my LS1.
Old Jun 28, 2007 | 02:58 PM
Thats due to the better design and more efficent combustion chamber, putting more timing to a LS1 doesnt gain due to the heading being so good.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
