The 3.73's are in! Finally
Old Jun 26, 2007 | 10:10 PM
bombebomb's Avatar
Well after over 6 months of them laying in my closet there in today costed 250, Im breaking them in currently and my speedo is off, so I cant really say I can tell a difference yet. I got to baby it until there broken in, ill keep yas posted to, thanks capn pete, and everyone else who replied to this post months ago http://web.camaross.com/forums/showthread.php?t=486742
Old Jun 27, 2007 | 06:06 PM
bombebomb's Avatar
250 miles until there ready to be beat on, my speedo is 30ish mph off, I can't find no one here that will make it right though, I went to the chevy dealership and they said they can't help me. Anyone have some ideas, I cant do a mail order because I don't have the wire. Im in ohio south eastern if that helps.
Old Jun 27, 2007 | 07:12 PM
myslowcamaro's Avatar
sponsor on here
http://www.trifectaperformance.com/
Old Jun 27, 2007 | 09:41 PM
Your transmission is not going to shift right until you get the calibration for the gears corrected.
Old Jun 28, 2007 | 09:13 AM
bombebomb's Avatar
Ok guys thanks, I can't believe no dealerships can fix this, ud think they could.
Old Jun 28, 2007 | 04:13 PM
Moshbmx1's Avatar
I just got my 3.73's in not to long ago too and I hit it for the first time from a rolling first gear and couldnt keep the back end behind me. I cant imaging what the 3.73's will do once i hit it with the nitrous too.....hopefully u can get the speedo corrected and break-em in and start to enjoy them. If you can spare some downtime on the car then send the PCM out to get corrected, if you dont want to buy the cable.
Old Jun 28, 2007 | 04:27 PM
bombebomb's Avatar
Im pretty sure that trifecta link comes with the cable. Did you notice any change before you got yours returned, because I don't notice a difference, I have not tooken it over 3 grand yet though.
Old Jun 28, 2007 | 04:33 PM
Moshbmx1's Avatar
I didnt romp on it for about 200 miles or so but during that time no, nothing really.
Old Jun 28, 2007 | 07:10 PM
showstoppers-96-Z/28's Avatar
thats as straight forward as it gets, fix your pcm, and get the shifts on the bang.
for you to notice the 3.73 difference, you will have to lay into it, these are gears dude, they're not like internal engine parts which have to "break in" before hard use because of normal wear and tear, these are not made of a very fragile material, as long as there is sufficient and correct grade lube in the rear, the gears are either right or wrong and will work or fail, the bearings are the only things in there that really have to "break in", i laid into mine 5 miles away from the shop to see what they could do, even tho i didnt tack it, the change was awesome, a night and day difference, when i got my pcm re-tuned by MadZ/28 ('mad tuner' now) it hit juuuust right, now i need a shift kit to slam gear to gear and help me knock my time down a bit, but i think you will be very pleased once you nail it, i encourage you reach the mileage that makes you comfortable, and try them out
Old Jun 28, 2007 | 08:08 PM
11secgen's Avatar
me to, i drove the crap out of it right off the bat.the manufacture says to not romp on it for 200 miles so will be able to detect any problems with the install before you ruin the gears and cry defect.
Old Jun 28, 2007 | 10:34 PM
bombebomb's Avatar
Looks like ill be waitin until I get another 200$ before I can beat on it for a tune. Alwell.
Old Jun 29, 2007 | 02:17 AM
Z-RATED94's Avatar
Theres a proper break in procedure for a reason.
Old Jun 29, 2007 | 11:08 PM
bombebomb's Avatar
Ok, gears got quite a few mile son them now, I took it out today and got on it a few times, broke loose in 1,2, and when it shifted into 3rd. I can definently tell a difference, but still don't know how much because the speedo is off.
Old Jun 30, 2007 | 04:34 PM
Moshbmx1's Avatar
Just watch that 1-2 shift. I dont know how your trans is set-up but if its anything like mine then its pretty agressive. I was coming off of an off ramp and making a pretty agressive turn and it hit the 1-2 shift and brought the back end around on me. Of course i was following a new GTO that couldnt pull away from me even when i wasnt spraying so i had my hand on the button to turn on the n20 after i got around the turn....lesson learned definately keep two hands on the wheel and turn the juice on sooner
Old Jul 9, 2007 | 08:19 AM
bombebomb's Avatar
Ok, the gears are broken in 1100miles on them, changed gear oil today, Iv gotten into it pretty hard multiple times, and I love them, once I get the tune, it will be even better, the car shifts hella hard to people are claiming shift kit all the time.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
