Vortech V1 no boost
Old Jun 26, 2007 | 03:10 AM
Jeff97camaro's Avatar
Vortech V1 no boost
Got a 95 Z28 that was given to me, it has a Vortech V1 kit installed but has no boost. Thought it might be a simple issue of a clogged map sensor as it is consuming a little oil, but no such luck.
Car is a A4, stock other than the SC and has roughly 130,000 miles on it.
Any tips.
Old Jun 26, 2007 | 03:53 AM
94formula350's Avatar
first thing id check for...not to make ya sound like an idiot...
is make sure the belt is there,and tight.
second,check the boost tubes,make sure one didnt blow off,or come loose
Old Jun 26, 2007 | 11:24 AM
roguedriver's Avatar
I'll assume your looking for boost on a boost gauge. Is the line on the boost gauge hooked up?
Ken R.
Old Jun 26, 2007 | 02:38 PM
OBE1 95Z28's Avatar
They system uses a bypass valve, if this valve is faulty or the vacuum line going to the valve is faulty, the engine won't go into boost.
Old Jun 26, 2007 | 03:31 PM
jsetzer's Avatar
Are you reading the map sensor with a laptop? Of course it won't show boost....
How have you determined you are not building boost?
Old Jun 26, 2007 | 03:57 PM
I'm getting no boost because the car isn't going like a bat out of hell and I get no whine from the blower itself. I need to get the car up on the rack and inspect the belt, but I'm starting to lean towards boost control valve.
Old Jun 27, 2007 | 10:38 AM
engineermike's Avatar
If you don't hear a little whine, then the blower is not spinning (or it's just an SQ model and is quiet). Make sure the belt is even on it. Or install a boost gauge.
Old Jun 27, 2007 | 11:10 AM
I spent some time last night checking things out. The belt does need to be replaced, but it was still tight. The big problem was the bypass valve had failed.
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
