rev limiter issues
Old Jun 23, 2007 | 10:50 AM
11secgen's Avatar
rev limiter issues
i have a 4l60e,2400 stall with the transgo shift kit,billit power servo,b&m master kit,beast sun shell housing,stock motor,4.10 gear.i also use tunercats
my problem is this;
after getting my trans rebuiltand installing the 2400 stall,but before i installed the 4.10 every once and a while my kickdown shifts would hit the rev limiter on the 1-2 shift.after installing the 4.10 the all the kickdown shifts hit the rev limiter BAD 1-4 shift.i tried adjusting the kickdown shift mph down to 33 mph on the 1st, 2nd to 70 mph and it still wont shift. my rpm threshold is 5350 for 1-2 shift and 5450 on the 3-4 and 5350 on the 3-4 shift.i raised my rev limiter to 6200, and it didnt help i also reaised my vss shift diag to 3700,but im thinking about craking it all the way up,would a vss diag problem effect anything but the 1-2?.my shift times are left at the stock points. i can email my tune file to sombody or post settings if needed,just let me know what questions you guys have about my tune.any help would be great.thanks
dan
Old Jun 23, 2007 | 11:28 AM
Airbornec507's Avatar
Your initial problem is not with the shift point but with your gear settings. Get your pcm flashed with the correct gear setting and you should be ok. If you still have the same problem lower the mph to 1,58,98,0,57,97 in the hot kickdown mode. Then set the desired rpm shift points in the hot kickdown rpm threshhold tables. Set the VSS to 3000 and everything should be good.
Old Jun 23, 2007 | 01:06 PM
11secgen's Avatar
thank you! i also just found that my cold kickdown thresh was 8000 rpm? i changed those to the same as hot.could i have a bad trans temp sensor?im going to test drive it now, ill be back to let you know what happened.thanks again.
dan
Old Jun 23, 2007 | 05:14 PM
11secgen's Avatar
it worked! (i changed the hot cold and normal),thanks again.
HarleyZ28
Oct 5, 2015 06:23 AM
cristian1311
Apr 22, 2015 10:20 PM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
KamaroL98
Oct 22, 2002 02:58 PM
