Lock up vs non lockup
Old Jun 18, 2007 | 06:09 PM
CamaroSS8887's Avatar
So i am putting in a th350 and B&M makes a lockup kit for the th350 converter. Is this worth... What are the diff between the two.
Old Jun 18, 2007 | 06:17 PM
1987IROC350's Avatar
Lock Up vs. Non-Lock Up
Newer TH350s use a lock-up torque converter. The advantage of the lock-up is it is more efficient on the highway. When you are in third gear and the RPMs get to a certain level, the distributor triggers the torque converter. This makes the transmission work at a straight 1:1 with no lost power from torque converter slippage. These transmissions are considered to have 3 1/2 gears because of the lock-up.
The down side to the lock-up is the torque converter is not any larger than the non-lock-up version. The clutches take up a lot of space in the converter and so the converter tends to generate more heat. My transmission guy strongly recommended I get a non-lock-up version of the transmission because they last much longer.
The lock up version can be easily identified by the plug it has on the drivers side. It is normally a four prong weather pack plugs, not all the wires are used from what I've seen. The version that does not have a lock up torque converter doesn't have any wires to it at all.
It might be best to use the lock up version of the transmission if your engine originally used a lock up transmission. A different distributor is used with the lock up transmissions and the engine may be tuned for use with the transmission.
THE ABOVE WAS PASTED FROM
http://www.offroaders.com/tech/jeep/...D-gm-th350.htm
Aaront810
Aug 29, 2020 09:34 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
