WILL THIS EXHAUST HOLD??? (pics...) -need advice
Old May 21, 2007 | 08:31 PM
fredmr39's Avatar
Angry WILL THIS EXHAUST HOLD??? (pics...) -need advice
***Skip first paragraph for short version:
Alright....so I get home from work after my 2 hour drive (BAD TRAFFIC....car ran unusually hot) and I get home, and discover after I go back into the garage that my driver's side exhaust hanger weld has given out and my exhaust is leaning very low on the driver's side of the muffler -- being supported by a combination of I-pipe and the tip on the other side pushing against something. No marks on the tip....nothing seems bent out of place, etc -- and I heard NO scraping at all, even coming in my inclined driveway leading me to believe that it came loose AS I came in the driveway or just while it was sitting there cooling down.
***Do you foresee any problems with the temp-rigged exhaust hanger below holding up until the weekend? (I can't miss work 7:30 to 4, I have about a 90 minute drive each way - mostly 45-55mph) -- I'm confident in it, but you never know what I may be overlooking. Thanks guys/gals!
=>if unclear - the primary source holding it is an extension cord piece wrapped where the hanger USED to be, and partiall aroud the fuel tank shield........if that fails, there is a metal loop made for hanging household pipes and the holes in that overlap and are tied with some 16 gauge speaker wire........that whole area is wrapped with electrical tape...mostly for a better appearance --------- the pipe with the single hanger is the passenger side - just in case...haha
PICS DELETED TO MINIMIZE THREAD CONTENT AND HELP SLOWER INTERNET USERS....OR, I GUESS I MEANT USERS WITH SLOWER INTERNET
-Only problem I see is some probable discoloring of the pipe behind the tip...
Old May 21, 2007 | 08:51 PM
reamo04's Avatar
youre going to melt that drop cord to your exhaust!
the metal part is fine though
take the drop cord off, use a clothes hanger
Old May 21, 2007 | 08:56 PM
fredmr39's Avatar
Damn does it get that hot? I felt like it would put up with the heat.....looks like I'll be back under there soon then...
(cutout will be open if this impacts decision at all -- one cutout before the axle bend)
EDIT: One person saying it will melt is all I need -- I wasn't sure it would because I have touched it before -- didn't seem severe at all.. Will go all metal now..
Old May 21, 2007 | 08:58 PM
reamo04's Avatar
i still wouldnt trust it. Have u ever tried touching your exhaust pipe? It gets extremely hot, why do u think it melts wires lol. Drop cord = no no. I would keep that metal part, and use 2 clothes hangers to wrap around there, and than i wuold feel safe about it
Old May 21, 2007 | 09:00 PM
shock6906's Avatar
You'll be fine with that plumber's tape. I don't know how you have it fastened to itself...hopefully a small nut and bolt. If it's just taped together, it'll likely come apart. FWIW, I held my exhaust up with some small steel wire for a few days until I could get my new exhaust built. It did just fine.
Old May 21, 2007 | 09:02 PM
mdacton's Avatar
yeah, take the cord off......coat hanger will be fine, I have had to do that before.
Old May 21, 2007 | 11:18 PM
fredmr39's Avatar
No - the tape was protecting/cosmetically enhancing the appearance. I was too lazy to use nuts/bolts on the galvanized steel wrap -- it was easier to get it tighter using 14 gauge wire in multiple places and looping it repetitively - knotting it, and then taping that up. I trusted that more than the nuts/bolts anyway because I could get 5 or 6 spots per wrap as opposed to one or two.
Anyways -- I would've been fine with the orange drop cord it appears. With the cutout open -- here were some exhaust temperatures I took at that location:
OPERATING TEMP
80*F ON the pipe at operating temperature
72*F ON the closest portion of electrical tape in the following pics
AFTER 10 MINS HARD DRIVING
92*F ON the pipe after 10 minutes of HARD running
78*F ON the closest portion of electrical tape in the following pics
The electrical tape can handle up to 176*F.
I heated the outer protective coating only of the drop cord in a microwave and read the temperature at 138*F - there was no melting.....though this was not a sustained temperature, it seemed unlikely to reach that touching the outer pipe surface...then again -- who knows once it's been running for an hour plus.
Whoever asked if I had touched the muffler area while/right after it was running -- yes I have, that's why I was under the impression it wasn't TOO hot there. (again, cutout)
(it may not look stable in some ways..but I assure you it is -- all of the angles are covered....and some look weird because I had to play with it to get the tips perfectly even with one another......the thin appearance of the galvanized steel is misleading as well)
SOME PICS REMOVED FOR QUICKER LOAD TIME/SHORTER THREAD
anything white you see is clothes hanger -- one comes from a weird angle you cant see just to cover anything that could go wrong..
within that black electrical tape is a...."sophisticated" network of wire, galvanized steel, clothes hanger and spark plug wire (used to pull galvanized steel ends together to "lift" the pipe higher)...
NOW will I be fine until Saturday when I don't work? (or at least after Thursday when I get my paycheck) - even after I get the work done -- I will keep a clean looking loop of galvanized steel bolted together on each side -- good insurance....
THANKS FOR ALL OF YOUR ADVICE!!!
Old May 22, 2007 | 08:54 AM
shock6906's Avatar
Yeah, you'll make it to Saturday.
Old May 22, 2007 | 12:50 PM
LiENUS's Avatar
Why not pull the muffler off entirely?
Old May 22, 2007 | 01:30 PM
fredmr39's Avatar
Welds.
Old May 22, 2007 | 01:35 PM
vdubois's Avatar
Ghetto Fabulous, Coat hanger + 1
I have seen a lot worse, looks like its time for some duals.
Old May 22, 2007 | 01:43 PM
2000GTP's Avatar
It looks like you emptied out every spare thing you had in the garage to fab that up. Don't think it is going to go anywhere on you. I had that bracket break on me as well that holds up the drivers side tailpipe. Luckily I have a welder at home, it made a quick fix for that.
Old May 22, 2007 | 02:14 PM
fredmr39's Avatar
LMAO - I definitely did.
Old May 22, 2007 | 03:03 PM
MyRed93TA's Avatar
[edit]
Last edited by Injuneer; May 22, 2007 at 05:15 PM. Reason: Racial remark deleted. Knock it off!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
captcorvette
Mar 7, 2015 12:37 PM
David Dorris
Jan 17, 2015 08:10 PM
Killer94z
Jan 13, 2015 12:06 PM
