Visual signs a synchro is dead...
Old May 16, 2007 | 02:41 PM
v7guy's Avatar
When I have the synchro sitting in front of me out of the T56 is it obvious if it's shot?
Am I just looking for worn down teeth or are there other signs that it needs replaced?
Old May 16, 2007 | 06:55 PM
Capn Pete's Avatar
Aside from visually inspecting the teeth, to see if they're worn, burred, etc., there is also a measurement spec, something like .020" gap, when you place the synchro ring onto the gear ... the distance between the ring and the nearest face on the gear. Basically, what you're trying to measure is if the paper/carbon material of the synchro ring is worn too thin. If, when you place the synchro ring onto the gear (over the "cone"), it can press tightly against the gear face, then it's worn out. Like I said, I believe the book called for a .020" gap .
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
colts0455
Sep 27, 2015 01:07 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
NewsBot
Aug 21, 2015 09:40 AM
Aug 5, 2015 08:35 AM
