new wheels not fitting correctly
Old May 12, 2007 | 01:12 AM
sn8ke eatr's Avatar
i bought newer 97-99 rims for my 93 camaro. the fronts fit fine but the backs dont seem to clear the hub. is this because mine is rusty or does anyone else have this problem? how can i make them fit without ruining anything, can i just sand the hub or what, any help would be great
Old May 12, 2007 | 05:21 AM
Bow94z's Avatar
http://web.camaross.com/forums/showp...4&postcount=10
Old May 12, 2007 | 06:25 AM
amean94ta's Avatar
The 1993 to "late" 1996 4th Gen F-Bodies have a larger hub on the rear axle than on the front spindles. The rear axle hubs are about 0.03" larger in diameter than the front hubs. This problem was corrected in late 1996 model year or possibly in early 1997.
As a result, if you buy C4 or C5 wheels, or if you buy 1997 or newer F-Body wheels, they may not fit on the rear hubs of your 1993-1996 F-Body.
The solution is very simple. First, DO NOT FORCE THEM ON WITH THE LUGS! Very dangerous, and you may not be able to get them off. You need to lightly sand or grind (e.g. - Dremel) the inside diameter of the hub hole in the back of the wheel. Don't go nuts.... just remove enough metal so the wheel cleanly fits over the rear hubs, with no interference.
Think about doing this to all 4 wheels, so you can "rotate" the tires in the future.
This will not harm the wheels.... you are taking off the thickness of a sheet of paper. Just be sure you do a neat, smooth job. This will also NOT affect the centering of the wheels on the hubs. The 4th Gen wheels are "lug-centric" - they are centered by the conical lugs, not by the hubs.
Old May 12, 2007 | 10:59 AM
Generally, when you "copy and paste" its a good idea to acknowledge the source.
Old May 12, 2007 | 11:05 AM
always faster's Avatar
From the wheel/tire FAQ
Old May 12, 2007 | 05:28 PM
amean94ta's Avatar
sorry i just knew where to copy it forgot to add anything
Old May 12, 2007 | 11:36 PM
sn8ke eatr's Avatar
wow alright thanks a bunch for the help. i was planning on just sanding them a little but was worried about offsetting the balence but i guess thats not an issue, thanks again
anthony
sloppytot
Feb 25, 2015 08:30 PM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
