Knock Sensor
Old Apr 25, 2007 | 12:52 PM
btz28m6's Avatar
Knock Sensor
Hey guys have a knock sensor code (knock sensor low signal) Also have noticed a loss of power as of late. Any corelation between the two? Knock sensor causing timing issues? Please let me know what you think.
2000 m6 z
Old Apr 25, 2007 | 01:00 PM
smithtim's Avatar
yeah you'd expect if your getting a bad knock then your performance would go down a little as your most likely not getting the "ample combustion" in the engine.. I’ve heard in the past of similar situations actually being caused by a bad tank of gas but it could be various other mechanical things causing the problem and of couse it could just be the sensor messing up
Old Apr 26, 2007 | 08:17 PM
LastBreedLS1's Avatar
i just got the same problem with mine. the service eng. light when on and the dealer told me it was the knock sensor. it also claims that my O2 sensor is bad but i just change those. im changing the knocks on the weekend, and lets see if i gain some lost power back.
Old Apr 27, 2007 | 12:25 AM
btz28m6's Avatar
thanks let me know how that goes man....
Old Apr 27, 2007 | 02:35 PM
Kraest's Avatar
Retired
The knock sensor can seriously kill power if it's seeing false knock or doing other stupid **** to retard your timing.
I was seeing around 10 degrees of false knock (noisy Morel lifters and valvetrain setup) with my 408 and picked up around 20 rwhp once we deadened them.
Mike
KYWes
Jun 14, 2022 06:52 AM
350350
14
Aug 11, 2015 12:03 PM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
Noct
Jul 14, 2015 01:18 AM
asilomar244
Jul 12, 2015 05:53 AM
