Clutch
Old Apr 25, 2007 | 12:17 PM
Matt9767's Avatar
Clutch
Hi guys. I drive a 96 Camaro with the 3800 and M5. The car has just over 133,000 miles and still has the original clutch, as far as I can tell. Recently, the clutch began to slip. When driving down the road I can hear this whining/grinding sound coming from the front of the car (it's not bad, but it is noticeable). I had the brake pads replaced a month ago and had the mechanic check the wheel bearings and U-joints, which turned out to be fine. Does the clutch make a certain noise when it begins to go, or could this be something else? Any input would be appreciated.
Old Apr 25, 2007 | 02:07 PM
ConElite's Avatar
The clucth wont make noise it will simply slip and You will know its starting to slip.
Old Apr 25, 2007 | 02:17 PM
95LT1conv's Avatar
the T/O bearing will make plenty of noise
Old Apr 25, 2007 | 02:20 PM
ConElite's Avatar
Good point. Good wat to tell is, Press the Clutch in and rev it. If the noise is effected by the engine speed then it could be the T/O bearing. If its more when your moving then the wheel bearings might be done.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
