How many Bolts hold on each exhaust manifold?
Old Apr 24, 2007 | 08:55 PM
CamaroRacing12's Avatar
exactly wats in title....im tackling it tomorrow...i can visually only see 2 but i bet there is at leats 4 for each manifold....i wanna be able to spray them down with some PB Blaster thats why i am asking
Old Apr 24, 2007 | 09:10 PM
2000GTP's Avatar
6 bolts for each manifold. It'll probably be easier to find and spray them from the bottom of the car.
Old Apr 24, 2007 | 10:41 PM
ok kool thx man....
Old Apr 25, 2007 | 12:03 AM
mrmint69's Avatar
Lets hope its 6 per side. Mine only had 5 on passenger side . Now i have aftermarket headers . Use a long straw on your PB Blaster container and feel for them. I would let them soak for a couple days and then once you break them loose hit them again and wait a few minutes. Don't forget about the EGR attachment on the back passenger side.
Old Apr 25, 2007 | 07:35 AM
2000GTP's Avatar
You probably had a bolt break off, not uncommon at all.
Old Apr 25, 2007 | 10:38 AM
njenson's Avatar
yup they are both right.. 6 bolts per side.
also, as he said above,if you dont have one lying around steal a straw of of a can of WD40 when you buy the PB blaster... spraying everything down made my header install sooo much easier... that and i only had 5 bolts on one side the bolt closest to the firewall was busted on the drivers side for me (as 2000GTP said it happens all the time)
Old Apr 25, 2007 | 09:40 PM
yea its sooo hard to get to the manifold bolts... this afternoon i jacked the front of the car up enough to get under there...and it was so hard to get to all of em...i didnt even get to hit all 12 with the PB Blaster
Old Apr 25, 2007 | 11:55 PM
njenson's Avatar
once you get the starter and alternator out of there its not too bad... that was another thing about spraying everything down so many times beforehand. I got a real good idea of where everything is. just try to imagine where everything is and get a little creative
The one on the front passenger side is probably the worst... just make sure you have plenty of different sockets and wrenches and just exparament to see what works
Old Apr 26, 2007 | 09:00 PM
yea thats my plan i have been at the bolts from every which angle to spray them down without removing anything...now im gonna start removing tings tomorrow after school and actually get goin on it...
Old Apr 27, 2007 | 11:01 AM
2000GTP's Avatar
Thats a good plan, I soaked all of my bolts for a few days straight before touching them with a socket wrench. Every single one came out with no resistance.
Old Apr 27, 2007 | 11:18 AM
yea its just hard to get to every single one of the 12 of em...with everything still in and not taken out...but i got most of em...while i was under there i sprayed every bolt i could see lol
Old Apr 28, 2007 | 03:41 AM
mrmint69's Avatar
I remember one bolt in particular that i could only only get to by shooting it straight up and i had to watch other wise it could go anywhere. No need to say anymore.
Old Apr 29, 2007 | 10:25 AM
what?
Old Apr 29, 2007 | 10:48 AM
93LEETZ's Avatar
I think he means he hit himself in the eye with PB Blaster
Old Apr 29, 2007 | 12:57 PM
9t1 z-28's Avatar
I heard a few of you say that it was rather common to break a header bolt whe removing the manifolds. How'd you go about fixing that?
