oil capacity?
Old Apr 17, 2007 | 07:34 PM
davidmullen73's Avatar
oil capacity?
Is the oil capacity for the LS1 5 or 5.5 qts? I'm asking because ever since I've owned my car...a little more than two years now...I've always used 5 qts and have had the oil level at the top afterwards. The more I am checking out these threads, I'm noticing that I should be using 5.5 qts. If this is true, why is my dipstick showing full after an oil change?
Old Apr 17, 2007 | 07:51 PM
SSpdDmon's Avatar
Owners manual says 5.5 quarts. If you don't have a copy, you can download an electronic one at www.mygmlink.com. It only takes a minute to register and it's free.
Old Apr 17, 2007 | 10:14 PM
og556's Avatar
I'm sorry for hijacking this thread but I'm sure this subject has been beat to hell on here... What weight oil can you use with the 02 z28 LS1 ? I have 12 quarts of Royal Purple 5w20 from my previous vehicle laying in my garage. Would that stuff be safe in the LS1 ?
Old Apr 18, 2007 | 07:29 AM
AL SS590 M6's Avatar
Moderator
5w-30
no
Old Apr 18, 2007 | 07:33 AM
IXLR894Z28's Avatar
5 quarts without filter change, 5.5 with.
Old Apr 18, 2007 | 07:37 AM
Moderator
I usuall just put 6 in it with a filter change.
Old Apr 18, 2007 | 08:42 AM
SSpdDmon's Avatar
Yeah, that's too thin. You want at least a 30-weight for our cars. If you're in a colder climate (like up by Canada), either a 0w30 or 5w30 will do. If you live in the mid~lower regions where temps never really get that cold, either a 5w30 or 10w30 will do.
Personally, I like to recommend the German Castrol Syntec 0w30. It's one of the few true synthetics on the market and costs a little more. But, many of the oil junkies have posted great results in their oil sample analysis that they sent off. The trick is to make sure it says "Made in Germany" on the back.
Old Apr 18, 2007 | 08:58 AM
Kraest's Avatar
Retired
6.25, but I have a Corvette
Old Apr 20, 2007 | 05:37 PM
jorgez28's Avatar
weird I put in 5qts and it always fills to the top????
Old Apr 20, 2007 | 06:03 PM
I guess the other 1/2 qt. is to get a jump start on the oil replenishment until the next change.....
Old Apr 20, 2007 | 06:38 PM
blackrat's Avatar
You can actually run a bit more oil then what the dipstick says. evidentally the ls1 has a high crankcase or something and a lot of the guys into roadracing and autox run an extra quart to stave off oil starvation during turns. just an fyi.
Old Apr 21, 2007 | 07:29 AM
^isn't running too much oil not good for the engine?....so I hear
Old Apr 21, 2007 | 08:38 PM
psychocabbage's Avatar
6qts for me too..
2002 Z..
Blackrat has it right.. its why I run more...
as for oil replenishment. .I have never ever had to add any to top it off before an oil change and I only change the oil when the light for the oil change comes on.
Old Apr 25, 2007 | 01:21 PM
Coolformula's Avatar
6 and the long oil filter
GC 0-30W is good ls1's like the heavier weight!
Old Apr 25, 2007 | 05:37 PM
Z28luvr's Avatar
what is this filter that you speak of? got a p/n?
RX Speed Works
Jul 24, 2015 02:25 PM
big_mac421
Jul 13, 2015 03:48 PM
jl1ne
Jul 7, 2015 08:38 PM
streetbad
Advanced Tech
Jul 5, 2015 10:40 PM
SergheiS
Jul 5, 2015 03:27 AM
